![]() | Home > Technical > RR sport - CRUISE CONTROL issue |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 920 ![]() ![]() |
Try disconnecting the battery for half an hour. May be a software glitch & needs a reset. Just a thought |
The hardest thing is if you have a full size spare is lifting it out of the way as its awkward to say the least. They give you a Heath Robinson strap which must have been designed by a five year old or Heath Robinson |
nil07 Member Since: 05 Apr 2015 Location: london Posts: 115 ![]() ![]() ![]() |
Got the following error code
Had the LR technician do,e out to me
car in grange Barnet and have been told there is a bracket which holds the radar behind the bumper.
They have now said they have fixed a bracket and there is no external damage to the radar unit....
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Wowa! Have I got this right? They are saying that:
Yes don’t quite get it ....
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5041 ![]() ![]() ![]() |
Not sure if it is the same bracket on a SVR as other L494's but that is a £15.00 bracket. The Sensor is around £1200.00 so if they want to charge £581.00 that is either a very cheap repair or more likely with L/R a very expensive £15.00 bracket.
Interesting ..... N
Price could include bracket plus taking bumper on and off etc.... I will await further info .... N
Just seems like a awful lot of money to me just to replace the bracket, although will admit I don't know how much work is involved in removing and refitting the bumper and align the sensor. If it is anything like the previous model it takes about a hour or so to change the bumper.
So bracket damaged - but radar still didn’t work . So claimed radar under warranty. So damaged bracket covered .
