Home > General > RRS 2011 Autobiography SDV6 3.0 heater only blowing cold air |
C9LFS Member Since: 18 Apr 2017 Location: Kirkcaldy, fife Posts: 22 |
hi guys newly back into RRs ownership hoping someone can help, when I first start the car the heaters are like tepid for a minute or so then only blow cold air, have checked for air lock by opening the bleed screw, even after driving it 250 miles it was still stone cold, the cars temp stayed exactly in the centre off the dial where I would expect it to be, any ideas.
Wed Dec 18 2019 11:59pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 |
You need to get the fault codes read. |
Fri Dec 20 2019 6:09pm |
thanks am looking into getting the car to an independent specialist to have the codes read.
Sun Dec 22 2019 6:56pm |
thanks mate! wasn't sure where the best place would be closest to me |
Sun Dec 22 2019 9:18pm |
2nd vote for mmp |
Sun Dec 22 2019 9:36pm |
Ok so as everywhere is closed being xmas new year I soldiered away at it myself got a hold of a icarsoft lr v2.0 after checking the matrix wasn't blocked I narrowed it down to either faulty heater valve at the Fuel Burning Heater or the little water pump.
Fri Jan 03 2020 8:44pm |
B_Tank88 Member Since: 27 Dec 2019 Location: Earl Shilton, Leicester Posts: 12 |
Congratulations on the DIY fix! Always supremely satisfying.
Fri Jan 17 2020 9:22am |
Grantgronow0705 Member Since: 30 Nov 2024 Location: Bridgend Posts: 9 |
I am getting identical issue in my 2015 RRS SVR and have changed the solenoid and water pump on the FBH just as you did. One thing I haven’t done yet is reset all fault codes which I’ll try later. If nothing still works, I’m ready to stick a hammer to the car!!! |
Sun Dec 01 2024 11:55am |
