Home > Technical > Wheel rotation - is this normal?
Stevepd
I changed over to the winter wheels today. Removed the summer jobbies and fitted the winters and upon doing up the wheel nuts there was a bit of movement of the wheel rotating before opposing resistance was felt to then do the nut up. Is this normal as for the life of me I can’t remember if it was like this when I removed the winter earlier on in the year. Confused 2006 2.7 TDV6 HSE in Cairns Blue.
Post #590583 Mon Nov 18 2019 9:41pm
knwatkins
That's normal Steve. Just slack in the drivetrain. Kev
Post #590617 Tue Nov 19 2019 2:20pm
Stevepd
TVM 2006 2.7 TDV6 HSE in Cairns Blue.
Post #590626 Tue Nov 19 2019 4:33pm
Brit Plumber
It’s called backlash, you need a certain amount of backlash or you can have premature ware or even catastrophic failure. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #590670 Wed Nov 20 2019 9:32am
