Home > My Range Rover Sport > My new (to me) 2010 RRS TDV8
Page 2 of 3 <123>
aaronjb
Took about four days to finish the MINI in the end - timing chain and valve stem seals.. that did involve a trip to BMW to pick up a new Vanos sprocket bolt (stretch bolt - couldn't get the chain off without removing the sprocket, despite some people reporting success in doing so, so needed a replacement bolt) and crank pulley bolt (also a stretch bolt - I already had one but, er, made a mistake Laughing )
Anyway.. in the mean time, I've had to buy a new battery for the RRS and now, this morning, "Service Required" popped up on the display - I assume (and you know what assumptions make!) that means it needs an oil change, in the absence of any other information. Unless it's lying because the battery dipped to 9.2V when cranking, of course..
Might have to invest in a GAP tool to reset the light after an oil change, because the "stalk button dance" to reset the service indicator looks annoying!
Updated running costs to date (excl. fuel etc)
Date        Item                                      Price       VAT     Total Running Total
13/09/2019  MOT                                      £54.85    £10.97    £65.82      £65.82
13/09/2019  Alternator                              £284.00    £56.80   £340.80     £406.62
13/09/2019  Door latch                              £126.92    £25.38   £152.30     £558.92
13/09/2019  Labour for above                        £266.50    £53.30   £319.80     £878.72
17/10/2019  General Grabber AT3 275/45R20 110V x 4  £566.64   £113.33   £679.97   £1,558.69
17/10/2019  Alignment                                £66.66    £13.33    £79.99   £1,638.68
11/11/2019  New battery from Tayna                       --        --   £184.72   £1,823.40
 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #590404 Thu Nov 14 2019 2:48pm
If you intend keeping the vehicle for some time really worth investing in the Gap Tool, always easy to sell s/h if no longer required.
Post #590420 Fri Nov 15 2019 12:37am
aaronjb
Yup very true - just a £400 spend I wasn't planning right now Smile Then again .. the "Service Required" message has disappeared now Question
Very odd - unless it was a false positive due to the (verrrry) tired battery dropping to 9V when cranking; the message popped up immediately after everything in the cabin reset itself during cranking due to low voltage (which is noticable because the CD player starts hunting for a disc, screen goes black, takes a while to come back on etc). Will replace the battery and cross fingers, first! Whistle 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #590424 Fri Nov 15 2019 8:52am
aaronjb
So .. I invested in a Gap tool, and also had both front wheel bearings replaced with Timken units at the local indy - it's just too damn cold & damp outside to grovel around on the floor changing bearings, and since it won't fit in my garage..
18/12/2019  Front wheel bearing x 2                 £217.80    £43.56   £261.36   £2,084.76
18/12/2019  Labour for above                        £195.00    £39.00   £234.00   £2,318.76
This may be the most expensive car I've owned based on it's six months running cost Laughing still needs a rear suspension bush, front lower arms, ARB bushes and brake pipes doing at some point. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #592010 Wed Dec 18 2019 12:39pm
aaronjb
Nothing much to report since December aside from a couple of new rattles.. the General Grabber AT3 tyres are still excellent - nice compliant ride, not too noisy on the motorway, no big hit in MPG or anything like that.
Although I did find yesterday that, in the wet, giving it a boot-full out of a T-junction will result in a very nice four-wheel drift requiring a quick arm-full of opposite lock Whistle Whistle 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #596555 Mon Mar 16 2020 9:27am
MikeG
United Kingdom 2008 Range Rover Sport TDV8 HST Santorini Black
I'm dying to see the latest updated running costs on this, or did you sell up? Present-2008 RRS TDV8 HST
Present-2018 M4 Competition Pack limited edition in Riviera Blue
2017 M4 in San Marino BLUE
2016 M4 in Austin Yellow
2009 RRS TDV8- Alive tuned
Mitsubishi Evo X RS
Mitsubishi Evo 9 GT
Post #610676 Sat Feb 27 2021 8:28am
aaronjb
Nope I still have it! There hasn't been much to add really beyond MOT and a service.. which I should dig out the records for Smile
Not that it did very many miles last year... 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #610888 Tue Mar 02 2021 12:03pm
aaronjb
Added a few things I'd forgotten and I can't find the receipts for the oil (I bought enough for two services back in 2020) but:
Date        Item                                     Price      VAT       Total inc VAT   Running Total
04/06/2019  Towbar (ebay)                                                 £199.99         £199.99
13/09/2019  MOT                                      £54.85     £10.97    £65.82          £265.81
13/09/2019  Alternator                               £284.00    £56.80    £340.80         £606.61
13/09/2019  Door latch                               £126.92    £25.38    £152.30         £758.91
13/09/2019  Labour for above                         £266.50    £53.30    £319.80         £1,078.71
17/10/2019  General Grabber AT3 275/45R20 110V x 4   £566.64    £113.33   £679.97         £1,758.68
17/10/2019  Alignment                                £66.66     £13.33    £79.99          £1,838.67
11/11/2019  New battery from Tayna                                        £184.72         £2,023.39
18/12/2019  Front wheel bearing x 2                  £217.80    £43.56    £261.36         £2,284.75
18/12/2019  Labour for above                         £195.00    £39.00    £234.00         £2,518.75
04/06/2020  Advanced Factors Service Kit             £72.27     £14.45    £86.72          £2,605.48
11/09/2020  Aircon regas                             £62.50     £12.50    £75.00          £2,680.48
11/09/2020  MOT                                                           £40.00          £2,720.48
15/12/2020  Advanced Factors Service Kit             £72.27     £14.45    £86.72          £2,807.20
02/06/2021  Aircon regas                             £65.00     £13.00    £78.00          £2,885.20
08/09/2021  MOT                                                           £40.00          £2,925.20
08/09/2021  Aircon regas/Coolant tank/Faults         £425.50    £85.10    £510.60         £3,435.80
18/10/2021  Brake switch (Powerful UK)               £15.83     £3.17     £19.00          £3,454.80
18/10/2021  Door handle covers                       £50.00     £10.00    £60.00          £3,514.80
20/10/2021  New battery from Tayna                   £119.39    £23.88    £143.27         £3,658.07
One thing that is apparent is there is definitely an aircon problem Laughing and I'll need to add the receipt from Turners for an exchange engine ECU soon.. gulp. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #619015 Wed Nov 10 2021 11:39am
aaronjb
Fingers crossed the new (exchange) PCM from Turners fixes things, because I just paid the bill (mine failed the bench test, so I am hopeful)
10/11/2021  Exchange PCM from Turners                                     £609.90         £4,267.97
Still.. I suppose that's only £150/mo average on maintenance. I'll just keep telling myself that's a lot less than PCP on a new car... 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #619106 Fri Nov 12 2021 10:46am
I see that between Sept 2020 and Sept 2021 you only had an MOT and service items cost to pay. Got to be happy with a year's ownership for a couple of hundred quid. He says, looking on the bright side of things. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #619108 Fri Nov 12 2021 12:20pm
aaronjb
Yep, I think it's the standard JLR ownership experience:
99% of the time it's like running any other car (consumables, service, MOT)
1% of the time it's an eye watering repair bill Laughing
To be fair, if I'd done some of the work myself I could have saved a lot on labour, but a few of those jobs (like the header tank) were "Take it to the indy because I just don't have time" and some of them (like "Why does the aircon gas only stay in the system three months") are somewhat elective and I took it to the indy because I didn't have time - and paying someone to strip half the front end looking for a pinhole A/C leak is never cheap! (I probably should have just assumed the condenser and changed it myself - I still need to as the indy couldn't source one at the time) 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #619111 Fri Nov 12 2021 12:36pm
aaronjb
Update now that the car is fixed and running again - brilliant service from Avenger, would absolutely recommend them for anyone local(ish) to Peterborough - after a new low pressure fuel pump, fuel filter, key battery and a repair to the battery-box fuse box:
16/12/2021  Fuel filter, pump, fuse box              £447.21    £89.44    £536.65         £4,804.62
Shame I dropped £600 on that red-herring PCM. Oh well, nobody to blame but myself on that one! 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #620258 Fri Dec 24 2021 4:02pm
Bertbuckie
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Bonatti Grey
Dear god your not having much luck!
On a side note I really like the runing total thing. I kept all reciepts and may steal your idea thanks Very Happy
Post #620261 Fri Dec 24 2021 4:23pm
NoExpert
What’s that old saying, “There’s nothing more expensive than a cheap Land Rover”.
I admire your persistence though. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #621502 Wed Feb 02 2022 7:09pm
Hightimo
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Sounds like you have the ac issues fixed now but just so you know I had a 2007 discovery 3 re-gassed at Halfords and a ac health check and it was on a deal for £50 not that long ago
Post #621671 Tue Feb 08 2022 6:41am
Page 2 of 3 <123>
