Home > Maintenance & Modifications > Coolant Question
the_big_1
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Fuji White
Coolant Question
Hi Guys,
Just looking to buy antifreeze for top ups extra.
Looking in the workshop manual, it states "Havoline XLC" a searching I found that "Prestone Dex Cool Extended Life" is a direct replacement. see below.
I found this in Toolstation, what do you think? Or other than my main dealer who is hard to get too for me, any other suggestions? The colour appears to look oragnge in colour.
https://www.toolstation.com/prestone-antif...use/p30499
Havoline XLC - info from MSDS: https://www.conncoll.edu/media/website-med...freeze.pdf
Ethylene Glycol 80 - 96.99 % weight
Diethylene glycol 1 - 4.99 % weight
Potassium 2-ethylhexanoate 1 - 4.99 % weight https://pubchem.ncbi.nlm.nih.gov/compound/...ection=Top
Water remainder of weight
Prestone Dexcool Extended Life - https://docs.google.com/viewerng/viewer?ur...;toolbar=1
Ethylene Glycol 80-95 % weight
Diethylene Glycol 0-5 % weight
2-Ethyl Hexanoic Acid, Sodium Salt 1-5 % weight https://pubchem.ncbi.nlm.nih.gov/compound/...ection=Top
Neodecanoic Acid, Sodium Salt 1-5 % weight http://chem.sis.nlm.nih.gov/chemidplus/rn/31548-27-3
Water remainder of weight​
Post #589766 Sun Nov 03 2019 12:06pm
Stevepd
Try this:
https://www.rrsport.co.uk/forum/topic54889.html
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #589774 Sun Nov 03 2019 1:16pm
the_big_1
Hi ya,
Wasnt sure if it's the same stuff as mine seems to be an orange / red colour.
Post #589778 Sun Nov 03 2019 2:33pm
the_big_1
Guess this will do??
https://www.eurocarparts.com/p/triple-qx-r...-523770512
Post #589783 Sun Nov 03 2019 3:39pm
geoffsnook
Yes i did read somewhere its the red and not the blue you must use Thumbs Up
Post #589786 Sun Nov 03 2019 4:18pm
Yes.
Post #589789 Sun Nov 03 2019 5:16pm
the_big_1
So that coolant will be ok for top up, the euro car parts one?
Post #589790 Sun Nov 03 2019 5:31pm
Yes. Red Euro parts one.
If the postage is no more for 2
I would buy 2
Post #589795 Sun Nov 03 2019 6:16pm
djpgowrie
Hi all,
Just looking to piggy back off this topic - I need to top up my coolant and the manual says Castrol SF. The cap on the reservoir says use green not red but the plastic looks red stained (no fluid visible).
I've read the 2 can't mix so should I go red (Triple QX Red) or use factory recommended?
Thanks!
Post #600015 Wed Jun 10 2020 6:11pm
