Home > Technical > 2.7TDV6 2006, Turbo Actuator stuck in vertical position
holland389
France
Can I repair, change or fix the actuator on the car? When I remove the access cover behind the front LHS wheel arch I can see the top of the actuator. I push it with a long prod and it is solid. Also when I turn on the ignition I can hear the actuator motor trying to work.
Can I fix, replace the actuator on the car with body in place?
Post #589287 Sat Oct 26 2019 5:19pm
Not really.
The veins on the inside of the turbo maybe sooted up.
Put some vvt cleaner in the fuel tank
Post #589292 Sat Oct 26 2019 6:24pm
holland389
France
Sadly I think it's been like this for I've a year. I want to try to free the actuat or. I'll do the carbon clean as you advise. If for no other train than its probably overdue. A lot had come all at once. Brakes, discs, pads and not the front LHS shafts needs replacing. If the body has to come off then the car can go for scrap. I've had enough. If the actuator can be freed I'm give it a go. I juse wondered if there was a fix without removing the body. Did I mention that the hand brake middle need attention also. I do the work and it saves a lot. Almost renewed everything now
Post #589311 Sat Oct 26 2019 11:40pm
holland389
France
Sadly I think it's been like this for over a year. I want to try to free the actuator. I'll do the carbon clean as you advise. If for no other reason than its probably overdue. A lot has come all at once. Brakes, discs, pads and now the front LHS shaft needs replacing. If the body has to come off then the car can go for scrap. I've had enough. If the actuator can be freed I'll give it a go. I just wondered if there was a fix without removing the body. Did I mention that the hand brake unit needs attention also. I do the work and it saves a lot. Almost renewed everything now
Post #589312 Sat Oct 26 2019 11:43pm
Ppl do change the turbos on these with body in.
Post #589321 Sun Oct 27 2019 8:58am
SRE
Spain
If you manage to free it off, then I would only ever use Premium Diesel in the future. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #589322 Sun Oct 27 2019 9:15am
holland389
France
So I've been researching and both the actuator arm sticks and the vanes soot up. Got some Kano Kroil for releasing the arm. Is it OK to use releasing fluid on the internals of the vanes. I can remove the exhaust bellows and get liquid into the turbine chamber.
Post #590922 Sun Nov 24 2019 1:09pm
don't see why not.
If you have got the exhaust off, you may as well change the turbo! Laughing so be prepared for that
front prop shaft has to come out for access (for both I guess)
Post #590925 Sun Nov 24 2019 1:59pm
