Home > General (L494) > RFID (Faraday) Pouch - Failures |
I bought 2 from amazon & both are still working fine,i always have one in my pocket at work as sometimes ive caught the boot remote by mistake & had customers come in my place to tell me my boot is open so I know keep them in my pocket in a pouch & I know it works as when I finish work I sometimes forget to remove key & car wont open. Andy.
Thu Oct 24 2019 6:37am |
MrM Member Since: 16 Jan 2016 Location: London Posts: 146 |
Could you not disable keyless entry and then you don’t have to worry? |
Thu Oct 24 2019 8:44am |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 410 |
i've disabled mine and can sleep peacefully now |
Thu Oct 24 2019 11:26am |
RRT Member Since: 26 Mar 2018 Location: South Coast Posts: 248 |
I have ordered another one of a different brand. I put a good bunch of keys inside the pouch and maybe it is wearing away a metallic coat.
Thu Oct 24 2019 11:34am |
The other thing to watch out for is that in some of them only one side of the Faraday mesh liner is sewn to the wallet and it is very easy to slip the keys between the mesh and the plastic wallet. The pouches I bought off Amazon it is very easy to think you you have put it in correctly but in fact you haven’t actually put it inside the mesh part of the pouch.
Thu Oct 24 2019 1:26pm |
UPDATE
Thu Jan 09 2020 11:37am |
chi Member Since: 15 May 2010 Location: hampshire Posts: 49 |
Same for me . Two pouches failed after about 8 weeks use.
Thu Jan 09 2020 11:54am |
Ash3 Member Since: 31 Aug 2019 Location: London Posts: 279 |
Ditto...I use pouch and it still works...but disabled keyless entry too...just in case |
Thu Jan 09 2020 1:00pm |
Aguiness Member Since: 31 Dec 2018 Location: Stirling Posts: 49 |
Hi I’m not sure how a pouch can fail, the pouch has a material woven into it to stop the signal getting out and in
Thu Jan 09 2020 4:03pm |
louischristie8 Member Since: 05 Jun 2012 Location: london Posts: 61 |
Is it 100% confirmed that disabling the keyless entry removes the theft / break in threat? |
Thu Jan 09 2020 5:15pm |
dazzerboy Member Since: 18 Sep 2009 Location: staffordshire Posts: 212 |
How do you disable keyless entry ? |
Thu Jan 09 2020 5:17pm |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 |
If you disable keyless then you have to use the remote’s buttons. When you use the remote’s buttons you are transmitting a signal that can be intercepted and recorded for playback, thus opening your car. I have a friend who lost their Q5 in this manner from a multi-storey car park. So disabling-keyless approach may or may not present a better risk profile than using keyless depending on your circumstances and your luck. I am referring to prior to MY18, because from then on I understand JLR security got a bit more sexy.
Thu Jan 09 2020 9:08pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
I use a little tin to keep my keys in. In addition, it's no where near the front door. Kev
Thu Jan 09 2020 9:16pm |
HaggisMan Member Since: 24 Apr 2018 Location: Glasgow Posts: 137 |
If you use a metal box (as I do) make sure there are no holes/gaps whatsoever. I initially bought a key safe but because of the tiny gaps around the hinge it didn’t work. A cheap metal tin with a tight fitting lid works a treat and although in have a 2019MY car with the more advanced security, I still keep the keys in the box at all times when I’m not driving it. |
Thu Jan 09 2020 9:36pm |
