Home > In Car Electronics > Thinkware Dashcam F770 Very Slow to 'Lock-on' to GPS Signal? |
Evo5man Member Since: 04 Jun 2017 Location: Skegness, Lincolnshire Posts: 222 |
GPS signal booster kit ordered from China
Sat Oct 05 2019 5:48pm |
UPDATE: After all the feedback from the forum (many thanks everyone)and Thinkware Customer Support, it seemed conclusive that it was the heated front screen that was blocking the GPS signal. So, I ordered a GPS signal booster kit from China (£7.76 on eBay) which arrived a couple of days ago. The booster kit comprises of an external antenna which has a magnetic base and an internal amplifier which has a USB cable connector for power. The external antenna and the internal booster are connected via a cable from each unit (with plenty of length for cable routing) which has a screw connector. I also ordered a power converter from 12v DV to 5v USB (£3.25 on eBay) so I could hardwire the internal amplifier into the car. EXTERNAL ANTENNA INTERNAL AMPLIFIER POWER CONVERTER Before deciding on how to hardwire the kit into the car and where to locate the external antenna, I decided to connect the kit and see what results I got. Prior to fitting of the booster kit the GPS connection time to my Thinkware F770 (with the car stationary) averages about 10 minutes, after connecting the booster kit the connection time is about 30 seconds, so I am very impressed with the results I will update this thread again after I have semi-permanently fitted the components but so far so good |
Fri Oct 18 2019 3:00pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1841 |
I would say from experience that it can be anywhere in the car as long as it has a reasonable view of the sky.
Fri Oct 18 2019 3:58pm |
I was originally thinking about fitting the antenna externally on the front windscreen plastic scuttle just to the side and below the wiper arm mounting on the passenger side with some double sided tape. It would be less obtrusive there and would still get a good view of the sky. I could feed the cable under the scuttle and through the front firewall into the cabin.
Fri Oct 18 2019 4:53pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4982 |
Excellent, look's like will be ordering one.
Fri Oct 18 2019 9:19pm |
I am sure it will work inside. 2023 P440e SE Dynamic on order -cancelled 2022 HSE Dynamic P400e 2017 Discovery 3.0 HSE Silicon Silver Nimbus interior and a few extra toys SOLD 2013 HSE Black, Orkney Grey, Ebony Seats and Ivory Interior SOLD 2006 HSE Plus a few other cars inbetween! |
Sat Oct 19 2019 7:05am |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
Interesting thread. For what its worth, I've had a double cam Thinkware F770 for a few years now and most of the time its connected to GPS within a minute or so - so before I've even got out of my drive. But just occasionally it has a delay of about 5 minutes. And yes, I do have heated screen elements. Robin
Sat Oct 19 2019 12:43pm |
Hi Robin,
Sat Oct 19 2019 12:59pm |
Does this help?
Sat Oct 19 2019 1:01pm |
Thanks for the quick reply
Sat Oct 19 2019 1:19pm |
I think you're right. However, just had a quick look at mine and it looks to me like the heating elements do go into the hatched area. I think I can see them glinting a bit in the sun - but it could be my imagination.
Sat Oct 19 2019 1:28pm |
Mine is located here, sometimes connects straight away, other times forever especially if on the move. At one point if I remember correctly it was o.k. but since had screen replaced (twice) it has got worse.
Sat Oct 19 2019 8:36pm |
Hi Col,
Sun Oct 20 2019 8:14am |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 |
I thought the hatched area on windscreens was meant to be the area devoid of transflective coating/heated elements etc so that things that need to see 'sky' can? I remember the instructions for my French automatic toll dongle said to install it in the hatched area if one was present, for exactly that reason.. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S |
Sun Oct 20 2019 9:41am |
