Home > In Car Electronics > Thinkware Dashcam F770 Very Slow to 'Lock-on' to GPS Signal?
Page 3 of 3 <123
Main reason appears to be to reflect U/V rays and reduce temperature of glass.
Post #588931 Sun Oct 20 2019 10:27am
jimbg
jimbg wrote:
Evo5man wrote:
But I might try a temporary internal fix on the plastic tray between the rear quarter fixed glass and the retractable boot cover Thumbs Up
I will post the results on here Thumbs Up
I am sure it will work inside. Thumbs Up
Did it work OK as a final solution or did you mount it outside? 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #590889 Sat Nov 23 2019 10:02pm
Evo5man
United Kingdom 2013 Range Rover Sport SDV6 HSE Lux Orkney Grey
Update:
First I tried a temporary fix on the internal plastic trim below the rear quarter glass. The receiver had a good view of the sky but could not get a GPS fix.
Next I tried a temporary fix on the internal plastic trim below the rear hatch glass. The receiver had an excellent view of the sky but again could not get a GPS fix.
When I temporary fix the receiver external to the car I get a GPS fix within about 30 to 45 seconds?
Could it be the Pilkington OptiKool glass that is preventing a good GPS signal inside the car in addition to the heated front screen?
I am now looking at the possibility of fixing the GPS receiver externally in the top corner of the front windscreen and running the cable down the inside of the black A pillar trim, below the black plastic scuttle trim and through the engine bulkhead into the car.
Other priorities have prevented me from moving the project on at the moment but I will update this thread again when I have a permanent and working fix Thumbs Up
Post #590892 Sat Nov 23 2019 10:55pm
Eaters
This is very strange as I don't have anything like the problems you've got. However, I have noticed one difference regarding the glass:
Perhaps it is the difference between laminated and toughened glass... Question Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #590907 Sun Nov 24 2019 8:58am
Eaters
Doh! Just realised your picture was of the rear glass, and like mine that is toughened. So that shoots down my theory although there are differences in the code. Does your front screen label match mine? Here's my read quarter-light label. Previous picture was of the front screen
 Robin
Gone:
MGZTT 190 2.5
Post #590908 Sun Nov 24 2019 9:05am
My front screen says acoustic on it which I think is actualy laminated glass the same as the front door glass.
Post #590912 Sun Nov 24 2019 9:38am
Just tried one of these on mine as well, only fitted temporarily with antenna part located on the roof but worked well and took about 30 seconds to connect, when have a bit more time will see if I can find location inside the vehicle where it will work, if not guess it will have to be externally some where.
Post #591227 Sat Nov 30 2019 5:35am
Page 3 of 3 <123
