Home > Maintenance & Modifications > 2009 RRS SC 4.2L Oil Light Issue
rayodunne
Canada 2009 Range Rover Sport Supercharged Santorini Black
So I had the oil light come on 100 yards from my house a week ago. Had a mild heart attack and checked oil level and topped up. It was low but above minimum level mark. I had it towed to the shop and they replaced the sensor. The light went out for the mechanic but was lit when I picked up the truck. We disconnected the sensor and started the truck and the light stayed on. Being that this is a simple switch to ground sensor the light should have extinguished as the circuit is broken. The light went out and stayed out until today. The engine drives and sounds awesome and the shop changed oil and filter when they had it.
I'm guessing a wire is rubbing a ground somewhere or am I on the wrong path here?
Post #588791 Thu Oct 17 2019 7:12pm
Tyrefitter
What Truck do you have.? I’m a Scania trained mechanic Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #588793 Thu Oct 17 2019 7:23pm
rayodunne
2009 Range Rover Sport 4.2L Supercharged, Jaguar Engine
Post #588795 Thu Oct 17 2019 7:51pm
At least 2 other occourances on diesels.
Post #588796 Thu Oct 17 2019 7:54pm
rayodunne
I found a thread on the LR3 having an oil light issue with water ingress on the A-Pillar. Apparently the water lands on the fuse box behind the glovebox and causes the light. There was a TSB.
https://landroverforums.com/forum/attachme...r-leak.pdf
Did not find one on the RRS.
Post #588797 Thu Oct 17 2019 8:02pm
rayodunne
So today the oil light came on but this time I had my fog lights on and the fog light symbol on the dash went out when the oil light came on. Neither rear or front fog light symbols on the dash work when the oil light is on. When the oil light comes on I also get whatever messages I got on startup like "low washer fluid"
My trucks voltage while driving is 13.5 or 13.6. I thought it should be above 14? 2009 Range Rover Sport Supercharged
Post #589123 Wed Oct 23 2019 12:05pm
rayodunne
Codes from Instrument Panel
Post #589125 Wed Oct 23 2019 12:06pm
rayodunne
Came across this image today. Added to my list for the weekend.
Post #589131 Wed Oct 23 2019 2:53pm
Rolling with laughter Rolling with laughter Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #589134 Wed Oct 23 2019 4:53pm
Brit Plumber
Mine has a plastic cap seal thingy which I assume is to stop water ingress. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #589135 Wed Oct 23 2019 5:49pm
aaronjb
"Chassis tit" .. Laughing Laughing Laughing That's what I'm going to call every ground stud, from now on.
Cleaning every 10k seems a bit much, mind.. clean, refit with good quality dielectric grease (preferably silicone based) and refit cover cap and you'd be good for .. a long time, I'd have thought! Still, worth investigating. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #589157 Thu Oct 24 2019 7:25am
rayodunne
I tried to locate this stud on the weekend and could not find it. Where exactly is it? 2009 Range Rover Sport Supercharged
Post #589381 Mon Oct 28 2019 3:27pm
PaulA
United States
Was this issue ever resolved? I have an 08 RRS oil light on, fogs don't come on, windshield fluid low warning on start--exact same prob as reported here. Was it the chassis tit/grounding or instrument panel? Am told it's the instrument panel and replacing will be $1500. Thanks all!
Post #611820 Tue Mar 23 2021 7:37pm
PaulA
United States
Low washer.
Post #611822 Tue Mar 23 2021 7:40pm
PaulA
United States
This oil light.
Post #611823 Tue Mar 23 2021 7:41pm
