![]() | Home > Maintenance & Modifications > 2009 RRS SC 4.2L Oil Light Issue |
What Truck do you have.? I’m a Scania trained mechanic Andy.
rayodunne Member Since: 17 May 2018 Location: Sudbury Posts: 41 ![]() ![]() ![]() |
2009 Range Rover Sport 4.2L Supercharged, Jaguar Engine |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5026 ![]() ![]() ![]() |
At least 2 other occourances on diesels. |
I found a thread on the LR3 having an oil light issue with water ingress on the A-Pillar. Apparently the water lands on the fuse box behind the glovebox and causes the light. There was a TSB.
So today the oil light came on but this time I had my fog lights on and the fog light symbol on the dash went out when the oil light came on. Neither rear or front fog light symbols on the dash work when the oil light is on. When the oil light comes on I also get whatever messages I got on startup like "low washer fluid"
Codes from Instrument Panel
Came across this image today. Added to my list for the weekend.
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9039 ![]() ![]() ![]() |
![]() ![]() ![]() 2008 TDV8 - it was a labour of love and is much missed |
Mine has a plastic cap seal thingy which I assume is to stop water ingress. 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
"Chassis tit" .. |
I tried to locate this stud on the weekend and could not find it. Where exactly is it? 2009 Range Rover Sport Supercharged |
PaulA Member Since: 23 Mar 2021 Location: CA Posts: 3 ![]() ![]() |
Was this issue ever resolved? I have an 08 RRS oil light on, fogs don't come on, windshield fluid low warning on start--exact same prob as reported here. Was it the chassis tit/grounding or instrument panel? Am told it's the instrument panel and replacing will be $1500. Thanks all! |
Low washer. |
This oil light. |
