Buckster
JLR to recall vehicles over engine hazard | |
Just seen this over on Disco forum
According to the national quality watchdog, Jaguar Land Rover will recall 68,828 vehicles in China due to an engine safety hazard:
https://www.globalbusinessoutlook.com/jagu...ne-hazard/ 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Sun Jun 30 2019 7:02pm |
Evo5man
Thanks Col,
I knew that you would have the answer
Just seen your earlier post and copied it below for others to see in this thread. Great minds think alike
The part I don't really understand is, they will do a fault diagnosis to determine if engine requires replacement fair enough, they also say the diagnosis will take about an hour, again fair enough, but there is no way they can remove the sump to check the crankshaft and bearings and refit in a hour, so if it only takes a hour to determine if it requires a engine change they must know what to look for as the tell tale signs, and if that is the case then why the hell can't L/R check U.K vehicles, unless of course they think they will find to many that need replacing. I did think the first people knew of the issue was when the vehicle stopped abruptly, I am prepared to accept I might be talking complete and utter rubbish though.
Wed Oct 09 2019 5:40pm |
