Home > Faults & Fixes > Rear door will not lock or unlock with key
Smunns
washed the car and went to open the rear door but would not open with the fob so i climbed into the car and unlocked the door from the inside but it will not lock when i lock the rest of the car, so does anyone know what i need to look at to get this problem sorted...........
Post #588282 Tue Oct 08 2019 6:27pm
knwatkins
You'll need to replace the latch in the door. Common problem. Kev
Post #588285 Tue Oct 08 2019 8:16pm
Smunns
Thanks for that and would you know the best place to get one???????
Post #588292 Tue Oct 08 2019 9:04pm
knwatkins
Without knowing the year of your car, no sorry.
I've replaced a few with second hand ones from eBay. If you are doing it yourself that's probably the cheapest way but if you are getting a garage to do it, you may as well buy a brand new part. Kev
Post #588296 Tue Oct 08 2019 9:26pm
Smunns
Thanks for your help knwatkins as i will order the part from eBay as i have found one on there and have a go myself........
Post #588334 Wed Oct 09 2019 5:21pm
Gandalf
Just done mine what a Censored pain in the Censored don't what ever you do follow powerful UK's vid remove the door handle then take out the whole assembly Thumbs Up my swear box is now overflowing Very Happy If it ain't broken down it soon will
Pulling my Vanmaster tin tent with my 2005 RED RRS HSE TDV6
1973 Land Rover Series 3 110 safari Gone but not forgotten
1990 Discovery 200Tdi Gone thank god
1996 Discovery 300Tdi sadly missed
2003 Discovery TD5 Gone to LR heaven
2004 Discovery TD5 Gone to Aberdeen hope it likes it there
2005 RRS HSE Rimini Red (my Disco 3 in a posh frock) sadly selling
Think I see a pattern here
Post #588360 Wed Oct 09 2019 11:20pm
Farmer Chalk
It is a really common part to fail but the components are specific on year and model so make sure you purchase the right part..
Island 4x4 and Advanced factors sell them.... as well as Britpart....
A genuine one is about £120 an oem type one is £30-40 .....
Absolutely take you time if you are going to do it yourself...when it comes to releasing the cables from the lock work out which bits to squeeze and use a small pick tool to gentle tease them apart... if you break the clips your Censored !
Also you will need to release the window from the motor.. this is dead simple if you know how! The easiest way is to remove the rubber strip that runs along the bottom of the window...this just levers up using a plastic spatula...but from memory there is also a small nut and bolt which secures it at the front end to the door skin... open the door and look at the hinge end and you will see the small nut...
Once you have that strip off you can see down inside the door...at the bottom of the window there are two plastic clips which clip into two holes at the bottom of the window pane...if you slide a plastic ruler or piece of rigid plastic down the outside of the glass into those white clips it will push open the lugs securing the glass...
It’s a tricky job which will take you a couple of hours but with care it’s rewarding when you’ve done it...
Inside the latch are two little scalextrix sized motors... one of these will have burnt out and hence the lack of locking action!
Post #588372 Thu Oct 10 2019 10:21am
Interesting, just replaced a rear one in mine and never removed motor from window, just dropped the whole unit motor and glass down inside the door a few inches.
Post #588375 Thu Oct 10 2019 10:29am
Smunns
Thanks guys you have helped me lots and think I am going to have a go on my own and see how I get on......👍
Post #588388 Thu Oct 10 2019 5:28pm
Gandalf
If it's an RRS1 like mine I just removed the speaker and you can see the clip that the window attaches to. Here's the video from pwerfull uk as I said ignore the lock refitting bit, you'll never get the new one back in it was simpler to remove the lock and handle together. If it ain't broken down it soon will
Post #588389 Thu Oct 10 2019 5:39pm
Farmer Chalk
Aaah... you can obviously get away with it then on the RRS...i’ve Replaced them them both on a Freelander 2 and a Disco 3 (same concept ) but the design of those doors makes it easier to remove the window unless you have incredibly double jointed and dexterous hands....
Only advice is be patient and don’t try and force things....
Post #588414 Thu Oct 10 2019 11:56pm
