Home > General > Exhaust blow sound from engine
Dylan
England 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
Hi I have a tdv8 that every now and then get like an exhaust blow from left side of engine if I turn off and restart all ok
Post #588027 Fri Oct 04 2019 5:56pm
What's in the fridge?
United Kingdom 2008 Range Rover Sport TDV8 HSE Buckingham Blue
I'm no expert but you might need to give a bit more info:
From your posts 2010 facelift with which engine? (helps if you stick it in your signature)
Mileage on the car?
Do you mean driver side or passenger side?
Area of engine noise is coming from- manifold at top, bottom etc?
Checked the pipes for split/ leak?
Any change in performance?
Throwing any codes up? 2008 TDV8 Buckingham Blue- SOLD
Post #588063 Sat Oct 05 2019 9:33am
Dylan
Hi this is a 2007 with a 3.6 tdv88 . It belongs to my cousin and he said it drives ok then it will start making a sound like a blowing exhaust . Sound coming from n/s engine but when he turns it off and restarts engine it is ok for a while will try and find some more info later
Post #588074 Sat Oct 05 2019 11:54am
Dylan
I have spoken to my cousin and he gets a loss of power but no warning on dash but if he turns engine off then back on it clears it so could it be the waste gate sticking
Post #588373 Thu Oct 10 2019 10:25am
