![]() | Home > General > 2012 sport no power on passenger side |
Steven 17 Member Since: 25 Sep 2019 Location: Wolverhampton Posts: 43 ![]() ![]() ![]() |
I’ve got a 10 plate sport to.im tempted to pull the door card off that one and plug that module in to see what happens |
Just checked speakers and they are working fine |
Just tried the door module off my 10 plate sport out of curiosity and mirrors worked fine windows worked fine but still no door locks.computer let me erase the door module too.but the module is a completely different manufacture code on the 10 plate.its basically got me back to when I first purchased the car.everything working apart from passenger front and rear lock even thow these are new parts.ive put the right module back in now and back to all faults again |
The 2010 unit should be an AH22 version which is ok, you’re maybe unlucky to have bought a bad replacement unit, was it new?
Hi bud yes it was a AH model.well I’ve actually tried 3 replacement ones now with the original part number and still no joy.they are second hand but promised to be working.i can’t get my head around how the AH works but original dosent.as far as the lock I purchased original Land Rover as I’ve head about the cheap copies not being good.im just wondering if the configuration of the AH module runs in a different way hence why I’m getting power back to everything but still no locks |
The AH is 2010, BH is 2011 and CH is 2012. These aren’t the years of production but the years of revision, hence a BH on a 2012 car. The 2012MY has a different infotainment system and some other differences but things like the door electronics were the same. The BH version is just a minor upgrade to the AH version, hence why it works.
Just found the wiring diagram for central locking and the lock command originates from an independent feed on the CJB. 2019 5.0 SC SVA (Current)
Ok so it stands a chance I could get away with fitting the AH module then?yes bud I left the battery off over night to try it but still the exact same.the lock itself must have some sort of power there as if I unplug the lock I just get a beep sound if trying to lock the rest of the car and no locks work then so there must be something running down the lock side but no idea what I should have and what I should have ha ha.i may order a fourth Bh module and see if that works and if not I’ll have to resort to the AH module then atleast I’ll only have the locks fault to contend with |
I’m thinking all this is down to the door module or a bad CAN connection.
Can you PM me your email address and I’ll send you a copy of the WS manual, there’s lots of stuff for diagnosing lock faults and how to adjust correctly. 2019 5.0 SC SVA (Current)
Any ideas on where this can bus connection is located?im still baffled as to why the original door module part number doesn’t work but the 2010 module does work. |
Will do mate thanks |
Bit of a update I’ve purchased a brand new module and fitted it today.and I now have power windows front and rear and mirrors fold in and out off the driver side switch.indicator now works on passenger side door too.just still have no locks working on passenger front and rear door.and mirrors not folding in when locking the car but I’m thinking that is due to the locks not locking the doors so just get a beep noise to say car isn’t locked.im happy the windows are all working but still baffled about the lock |
