![]() | Home > General > 2012 sport no power on passenger side |
Steven 17 Member Since: 25 Sep 2019 Location: Wolverhampton Posts: 43 ![]() ![]() ![]() |
Ok so I’ve checked with a multi meter the reading I’m getting from the power to ground is 8.57 volt.i tried the ground part of indicator to the ground on car and got continuity.ive pulled fuse 17 and 18 out and they are fine and working |
Well that’s quite odd, to get almost 9v, and have continuity to earth but not work....
I thought that but the thought it may have to be 12v.it didn’t fluctuate it stayed at 8.57.im going to pull the driver side indicator out tmoz and see what voltage I get there.ow and I did check the bulb was good ha ha.yes and solid continuity through the ground, dam car |
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 ![]() ![]() ![]() |
Water leaking onto CJB wouldn't be fun, but as far as I can see, everything not working goes into the same plug on CJB.
I really do hope it’s not that.ive actually taken that out and physically examined it and couldn’t find any signs of water or any damage what so ever.i so hope it isn’t that to be fair |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5042 ![]() ![]() ![]() |
What voltage? if any have you got on the yellow and red wire here at this connection, as that wire appears to be battery supply to at least the n/s front door module from the CJB connector C0586R.
Thanks mate I’ll give that a try.looking at that picture I’m guessing that is the main connection from the car to the door loom?ill do my best to get to it later.its a bit of a pain to get to |
Ok so I’ve found the yellow/red wire going to the door loom.put the multimeter on and I’m getting 11.96 volt going into the door.surely that is a good sign.so what could I possibly try now?any ideas welcome |
If you have power there then I suppose the next logical step is to test that wire at the door module.
I will check that next as the heavens opened as I was messing so had to give up.as soon as I’m home I’ll get the original one back out and the part fitted and give you the numbers.see if you can make any sense of it ha ha |
Yes I just replaced it with the exact same part number which is BH42 14D617 AA
Took a pic of the original |
It should upload this time ha ha |
