![]() | Home > General (L494) > RRS 2015 HSE Dynamic |
nil07 Member Since: 05 Apr 2015 Location: london Posts: 115 ![]() ![]() ![]() |
I had a 2015 model and had
Spleen Member Since: 04 Dec 2018 Location: Berkshire Posts: 175 ![]() ![]() |
I bought a 2017 RRS AB from Pentland Perth in Nov 18. Since then it's been to the local dealers eight times with suspension issues, faulty tailgate struts, braking system failures, vibration through the steering wheel, tracking problems, faulty blind spot monitors, EPB problems, air compressor replacement, replacement fuel lines and knackered engine mounts. LR Assist have been called three times to diagnose vibration/humming, EML light (stuck valve throttle body) and airbag light this weekend. It's also started squeaking underneath.
timhum Member Since: 06 Mar 2017 Location: Suffolk Posts: 389 ![]() ![]() |
I would suggest you ask the dealer to show you the complete on-line service, warranty and repair history.
45k for a hse dynamic seems a bit steep for a 15 plate unless I’m reading it wrong & that’s the mileage Andy.
What's in the fridge? Member Since: 14 Aug 2019 Location: Nearest hedge to London Posts: 112 ![]() ![]() ![]() |
Looks like mileage with LR history to me |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9017 ![]() ![]() ![]() |
Agreed. It's got 45k on it so I'm betting it's only had 2 services and they'll "service it for you" (i.e. just stamp the book) whereas a 15 plate should be looking at 3 or more likely 4 services by now. To the OP - remember the service is time or mileage so a four year old RRS should have 4 services (3 at the minimum if it was an end of plate vehicle. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 ![]() ![]() |
I have one. (2015 Dynamic);
