![]() | Home > In Car Electronics > Flickering dash warning lights |
mikeheley Member Since: 28 Jul 2013 Location: Bristol Posts: 6 ![]() ![]() ![]() |
sounds like a dash fault to me. |
rob cupples Member Since: 27 Jun 2018 Location: Stirling Posts: 30 ![]() ![]() ![]() |
I had exact same symptoms. I sent my instrument cluster away to clusterrepairs uk and the issue was solved. 220 pounds. the cluster is very easy to remove. when I pressed the back of the cluster the faults used to come and go. it's likely not your brake switch or brake light bulbs or if indicators staying on it's a canbus fault. I'd bet on simple instrument cluster fault. |
rayodunne Member Since: 17 May 2018 Location: Sudbury Posts: 41 ![]() ![]() ![]() |
I have a similar intermittent issue:
Drobe Member Since: 11 Jun 2020 Location: Warwickshire Posts: 9 ![]() ![]() ![]() |
I have the same intermittent issue with Oil light and LED display showing low washer fluid, replaced oil pressure sensor no joy!!!
Ended up replacing the instrument cluster with a used unit. Make sure the mileage is lower on the replacement unit!
