Home > In Car Electronics > Flickering dash warning lights
mikeheley
I'm getting a few lights flickering on my 2007 RRS.
They are front and rear fog lights on warning,
plus brake pad wear indicator.
I also get info messages for the brakes and
Low coolant.
None of these are valid warnings. I thought I'd try to reseat
The ECU connectors??
Would it be the one behind the battery.
Any suggestions gratefully received.
Thanks,
Mike
Post #587384 Mon Sep 23 2019 12:05pm
Brit Plumber
How’s the battery?
Any issues with indicators flashing, door locks operating etc? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #587387 Mon Sep 23 2019 12:13pm
sounds like a dash fault to me.
Post #587402 Mon Sep 23 2019 4:40pm
rob cupples
I had exact same symptoms. I sent my instrument cluster away to clusterrepairs uk and the issue was solved. 220 pounds. the cluster is very easy to remove. when I pressed the back of the cluster the faults used to come and go. it's likely not your brake switch or brake light bulbs or if indicators staying on it's a canbus fault. I'd bet on simple instrument cluster fault.
Post #587409 Mon Sep 23 2019 6:57pm
rayodunne
Canada 2009 Range Rover Sport Supercharged Santorini Black
I have a similar intermittent issue:
Symptoms:
Oil light comes on and Low washer fluid message. If front or rear fog lights are on, the light on the instrument cluster showing they are on will go out when this occurs.
Oil pressure sensor replaced and confirmed working, also washer fluid is full and message only appears in tandem with oil light.
I have read that the wires on the loom connecting the Instrument cluster can rub and short under the wire cover. Also a loose connector to the instrument cluster can cause this and a simple disconnect and reconnect can solve it. I have yet to pull the cluster as it's snowing now with no garage. 2009 Range Rover Sport Supercharged
Post #590032 Thu Nov 07 2019 4:31pm
Drobe
I have the same intermittent issue with Oil light and LED display showing low washer fluid, replaced oil pressure sensor no joy!!!
did you mange to get to the bottom of issue, was it the dash??
Post #601151 Thu Jul 02 2020 10:04am
rayodunne
Ended up replacing the instrument cluster with a used unit. Make sure the mileage is lower on the replacement unit!
You will need to pay someone to do the swap or if you have iidtool you can do yourself by contacting GAP and buying a software update file to do it. 2009 Range Rover Sport Supercharged
Post #601177 Thu Jul 02 2020 4:58pm
