![]() | Home > General > Which replacement tyres?!? |
Eskimo Member Since: 21 Oct 2018 Location: Worcestershire Posts: 72 ![]() ![]() ![]() |
I'm currently running 275/45 R20 Nexen Roadian HP and so far have been really pleased with them.
The M+S mark is fairly unhelpful really, it just shows that the tyre tread has some big grooves in it, basically. A winter tyre will carry M+S but having M+S on any other tyre doesn't infer any winter ability. Likewise All Terrains will have M+S but M+S doesn't infer any real off road ability.
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
I have Pirelli Scorpion Zero Asimmetrico 275/40/20 106Y on mine and for my purposes they perform brilliantly. Although I did my homework when the time came to replace I just couldn't find a better tyre so I played safe & loyal and I have no regrets whatsoever. (I can't put 275/45/20s on mine here in Portugal or it will fail the annual inspection.) Barrie.
Stu Member Since: 23 Jun 2019 Location: North Yorkshire Posts: 123 ![]() ![]() ![]() |
just after i bought mine in the summer i did as i always do and fit a set of A/T3's . I have had General Grabbers fitted on all my Range Rovers and Discos over the years. I have 275x45x20 on the RRS at the moment and i just love them. Current: 2010 RRS 3.6 TDV8 HSE
I've used the Grabber AT3 and it's a good AT tyre. I found it got a bit less grippy on wet tarmac once half worn but that's probably down to the sharp edges having gone and affects most tyres in some way compared to their as-new performance.
Silverstone Member Since: 04 Sep 2014 Location: Towcester Posts: 184 ![]() ![]() ![]() |
I dropped into my local LR/ tyre specialists (Loughrans at Towcester) this week to enquire about put 275/45 r20 AT3's on my RRS. They were very clear in explaining to me that if I swap from 40% to 45% profile tyres then I have invalidated my insurance. Do you guys declare to your insurers that you've swapped from 40's to 45's?
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 ![]() ![]() |
Not quite the same as I'm going from 20s to 18s but yes I tell the insurance wen changing tyre and wheel size 2012 SDV6 HSE (technically its hers)
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
I haven't fitted larger yet but considering the 275/45/20's instead of 275/40/20, when speaking with the insurer they said they need to know but it doesn't affect the premium (maybe not in all cases, this was at renewal).
I have a Fiesta that I use to hack to work in most of the time, it is fully comp with protected no claims etc etc. I was paying £20 per month for it prior to moving house. I have only moved from one end of a village to the other about 1/2 mile and only changed the last digit of my post code. I informed them of a change of address and they wanted £80 per month... |
Interestingly (or maybe not for some) |
map_rrs Member Since: 30 Jan 2018 Location: London Posts: 32 ![]() ![]() ![]() |
During the mid year months we make little or no use of our 06's off road capability (tarmac and unpaved roads) so we run OE sized 19" Avon ZX7 all round. Correct size, load and speed ratings, "A" rated for wet grip. They work well if you're making progress along cross country roads - we do an annual trip to central Italy, the ZX7s are great across varying types of roads, speeds and weather conditions.
