![]() | Home > Technical > "Wheel Alignment" |
Have you measured the centre of the wheel to the top of the wheel arch? It may be that the car is sat lower on one side making it appear the wheel is further back when it isn’t. 2019 5.0 SC SVA (Current)
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Suspension is all good. Recently replaced bags and compressor and suspension ride height is spot on.
I don’t think there are any shims, there’s definitely non for the front lower arms. If the wheel centre to arch are the same on both sides then it can only be the adjustments that have done that or something damaged. If it drives fine it’s probably the adjustments. I’ll have to have a look at mine. 2019 5.0 SC SVA (Current)
Thanks Brit Plumber,
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
Have you looked from underneath and comparred the two sides? |
Just checked mine and both identical. There’s only 4 mounting bolts on 2 control arms so can’t really assemble wrong. But something does look wrong. 2019 5.0 SC SVA (Current)
Oh and should have said my gaps are the same as the big gap.
Ok so I haven't had a look underneath yet but will definitely have to do that now.
It begs the question ‘How did they align if it’s possibly over 10mm out?’
Tbh I didn't as I've used the garage for years and they sub the alignment out. Also as it drove sweet with no fade to left or right, vibrations etc I didn't question it.
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
Do they have a Hunter 4 wheel alignment system? I’d take it somewhere else for this. I can strongly recommend a place in London but not elsewhere! (thetyreshop.com for the record)
Ilard, trying to find a competent 4 wheel alignment is hard enough, I doubt they have Hunter equipment. Took me 4 years to find a Hunter Road Force balancer...and that in a country overrun by Range Rovers....
While you’re under there, can you take some photos for comparisons. I’m intrigued as I can’t see in my head how it could be incorrectly assembled. It’s not rocket science under there so should be dare I say......obvio.... no I won’t say it. 2019 5.0 SC SVA (Current)
Cant wait to play spot the differance. |
