Home > Technical > "Wheel Alignment"
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
"Wheel Alignment"
I was looking to reinstall mud flaps on the front wheel arches and noticed that the drivers side front wheel 'sits' further back than the passenger side wheel.
Is this a common occurrence, and can something be done about it??
The car drives perfectly well, has been 4 wheel aligned recently etc etc. the only thing is the location of the wheel in the wheel arch.
I've asked the garage to check and they have confirmed the body is 'square'.
Any thoughts would be appreciated.
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #587190 Thu Sep 19 2019 10:03am
Brit Plumber
Have you measured the centre of the wheel to the top of the wheel arch? It may be that the car is sat lower on one side making it appear the wheel is further back when it isn’t. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #587191 Thu Sep 19 2019 10:11am
Guyzer73
Suspension is all good. Recently replaced bags and compressor and suspension ride height is spot on.
I'm thinking that perhaps something was installed back-to-front when they replaced all the bushes in the suspension, perhaps a shim or something that has resulted in this.
Kind of stumped really, especially as the Sport drives well... Confused 2006 RRS S/C CONSTANTLY under modification...
Post #587359 Mon Sep 23 2019 4:47am
Brit Plumber
I don’t think there are any shims, there’s definitely non for the front lower arms. If the wheel centre to arch are the same on both sides then it can only be the adjustments that have done that or something damaged. If it drives fine it’s probably the adjustments. I’ll have to have a look at mine. 2019 5.0 SC SVA (Current)
Post #587360 Mon Sep 23 2019 6:13am
Guyzer73
Thanks Brit Plumber,
It's a real riddle, but such a large difference can't be right. On top of which the rear is pretty much perfect to the eye.
Thanks for the help Thumbs Up Thumbs Up
Cheers 2006 RRS S/C CONSTANTLY under modification...
Post #587370 Mon Sep 23 2019 8:56am
PC76
Have you looked from underneath and comparred the two sides?
Post #587381 Mon Sep 23 2019 11:37am
Brit Plumber
Just checked mine and both identical. There’s only 4 mounting bolts on 2 control arms so can’t really assemble wrong. But something does look wrong. 2019 5.0 SC SVA (Current)
Post #587383 Mon Sep 23 2019 11:47am
Brit Plumber
Oh and should have said my gaps are the same as the big gap.
Have you actually checked and measured the ride height? I bet it’s possible to calibrate the suspension so it appears correct on the screen but not in actuality. 2019 5.0 SC SVA (Current)
Post #587385 Mon Sep 23 2019 12:05pm
Guyzer73
Ok so I haven't had a look underneath yet but will definitely have to do that now.
Just checked the wheel cap to wheel arch dims and both are 47cm +/-2mm.
However, checking the wheelbase on the passenger side it's 275cm which tallies with the specs. The driver's side though is only 274cm max, possibly slightly less. Which tallies with the visuals... Namely smaller gap to rear of front wheel arch on driver's side
So something is wrong there.... Confused Confused
Edited: spelling & additional information. 2006 RRS S/C CONSTANTLY under modification...
Post #587389 Mon Sep 23 2019 12:31pm
Brit Plumber
It begs the question ‘How did they align if it’s possibly over 10mm out?’
Did you get an alignment printout? 2019 5.0 SC SVA (Current)
Post #587396 Mon Sep 23 2019 2:08pm
Guyzer73
Tbh I didn't as I've used the garage for years and they sub the alignment out. Also as it drove sweet with no fade to left or right, vibrations etc I didn't question it.
Only noticed it when I looked at putting mud guards on the front and saw the limited space...
Time to go back to garage. 2006 RRS S/C CONSTANTLY under modification...
Post #587397 Mon Sep 23 2019 2:27pm
ilard
Do they have a Hunter 4 wheel alignment system? I’d take it somewhere else for this. I can strongly recommend a place in London but not elsewhere! (thetyreshop.com for the record)
But that said, you’ve just had the suspension done and now this... surely that job was done incorrectly.
Good luck solving this riddle! L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #587415 Tue Sep 24 2019 5:02am
Guyzer73
Ilard, trying to find a competent 4 wheel alignment is hard enough, I doubt they have Hunter equipment. Took me 4 years to find a Hunter Road Force balancer...and that in a country overrun by Range Rovers....
Yeah, I'd try them but it's a 15,000 km round trip Rolling with laughter
Yeah going to be an interesting riddle to solve. Taking onto the ramp hopefully tomorrow.
Post #587420 Tue Sep 24 2019 6:47am
Brit Plumber
While you’re under there, can you take some photos for comparisons. I’m intrigued as I can’t see in my head how it could be incorrectly assembled. It’s not rocket science under there so should be dare I say......obvio.... no I won’t say it. 2019 5.0 SC SVA (Current)
Post #587435 Tue Sep 24 2019 9:52am
PC76
Cant wait to play spot the differance.
Post #587441 Tue Sep 24 2019 11:42am
