Home > Maintenance & Modifications > What’s This MOT Advisory??
Sit
United Kingdom 2012 Range Rover Sport SDV6 HSE Firenze Red
Seen a potential purchase however the MOT history shows the following -
Offside Rear Upper Suspension arm pin or bush worn but not resulting in excessive movement Front bush
Near side Rear Upper Suspension arm pin or bush worn but not resulting in excessive movement Front bush
I get the impression from the forum this isn’t unusual, can I ask how it can be rectified? From my understanding this is common due to the weight of the car so I am guessing there is most probably an updated part out there somewhere I could fit??
Si
Post #586908 Fri Sep 13 2019 7:01pm
riverblanche
regular maintenance/wear of suspension parts, as you say they are a heavy lump and the bush's wear
just work on £250 each as a guide to what you will need to spend in the future, any clunks and its the near future Laughing
bargaining point get them replaced as part of the deal
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #586909 Fri Sep 13 2019 7:14pm
Sit
Thanks riverblanche that’s really useful, is it an OEM replacement or at £250 are we talking about an updated part??
Si
Post #586912 Fri Sep 13 2019 7:22pm
It's just a replacement bush. Often easier to just replace the whole arm. That replaces two bushes and ball joint. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #586924 Sat Sep 14 2019 12:05am
Disco_Mikey
Front Bush on the rear upper arms
Budget £250 a side (really Laughing )
Post #586928 Sat Sep 14 2019 5:19am
Oldandconfused
These bushes have some degree of compliance from new and it appears that it is the interpretation of the individual tester how much that should be.
I suspect that the bushes on my MY10 are original. On the last MOT no advisories, previous test at the same test station front lowers and one rear upper advisory. Previous MOT (different test station), no advisories, the one before (again different station) front lowers were advisories. In fairness, there is a very slight knock on jabbing the brakes at low speed, but no banging over bumps or uneven wear to the tyres, so although not urgent, I will have them done at some point.
Post #586932 Sat Sep 14 2019 7:39am
riverblanche
Oh Embarassed it seems I may be a bit out then Laughing
use £250 for each item that wants doing and may be it will balance out, some things must cost less than £250 Thumbs Up Porsche Cayenne 2022
Post #586975 Sat Sep 14 2019 7:11pm
Disco_Mikey
Some things are much less, some things much more
Whatever it is, it could be worse Laughing
Post #586988 Sun Sep 15 2019 7:36am
