![]() | Home > General (L494) > oil change |
Aguiness Member Since: 31 Dec 2018 Location: Stirling Posts: 49 ![]() ![]() |
Hi all
hi thanks
is the oil
I’ve got the same pump as that & yes it’s good,,the oil is 5/30 fully synthetic just make sure you get the right spec as their is loads of 5/30 fully synthetic. Andy.
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 590 ![]() ![]() |
Needs to be 5w30 Ford 913 D spec |
hi thanks
hi is the bellow the correct oil
NO that is a longlife VW 507 spec oil
great thanks i will
would this be ok
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 ![]() ![]() |
A few D4 owners use these. They work well. Search for best deal tho', this is just to show you..
To be honest I wouldn’t put long life oil in a engine with a dpf that has oil dilution problems,you need to be changing the oil regularly,mines in for service at LR today but in 6 months time I’ll give it another oil change using Castrol oil even though I only do 5-6000 miles a year,£60 for the oil is cheaper than a engine. Andy.
As above, 6k oil changes for an engine that only holds 5.9 litres is a good practice.
