Home > General (L494) > oil change |
Aguiness Member Since: 31 Dec 2018 Location: Stirling Posts: 49 |
Hi all
Thu Sep 12 2019 11:53am |
hi thanks
Thu Sep 12 2019 2:21pm |
is the oil
Thu Sep 12 2019 2:24pm |
I’ve got the same pump as that & yes it’s good,,the oil is 5/30 fully synthetic just make sure you get the right spec as their is loads of 5/30 fully synthetic. Andy.
Thu Sep 12 2019 5:07pm |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 588 |
Needs to be 5w30 Ford 913 D spec |
Thu Sep 12 2019 5:23pm |
hi thanks
Thu Sep 12 2019 5:48pm |
hi is the bellow the correct oil
Thu Sep 12 2019 8:16pm |
NO that is a longlife VW 507 spec oil
Thu Sep 12 2019 8:20pm |
great thanks i will
Thu Sep 12 2019 8:39pm |
would this be ok
Thu Sep 12 2019 8:41pm |
Thu Sep 12 2019 10:15pm |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 |
A few D4 owners use these. They work well. Search for best deal tho', this is just to show you..
To be honest I wouldn’t put long life oil in a engine with a dpf that has oil dilution problems,you need to be changing the oil regularly,mines in for service at LR today but in 6 months time I’ll give it another oil change using Castrol oil even though I only do 5-6000 miles a year,£60 for the oil is cheaper than a engine. Andy.
Fri Sep 13 2019 5:16am |
As above, 6k oil changes for an engine that only holds 5.9 litres is a good practice.
Fri Sep 13 2019 6:15am |
