![]() | Home > Technical > Suspension & Starting Issue |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 ![]() ![]() |
After jacking, the car can take a while to makes its mind up about heights and levels.
Not sure about the suspension, but the only thing that shut my S/C Brembo's up were EBC Redstuff brake pads.
Raise and lower the vehicle while moving to reduce the strain on the suspension as it changes geometry. In regards to the engine not starting after lowering, I’ve never experienced that but it could be something to do with your brake pedal switch seeing as you’d just replaced the brake pads. Had you pumped the brakes to bed the pads down? 2019 5.0 SC SVA (Current)
drb1709 Member Since: 24 Aug 2019 Location: West Sussex Posts: 38 ![]() ![]() ![]() |
Gents,
I can second Cols recommendation for Red Stuff, I followed his advice on another thread and although I never had a permanent squeal (very occasionally) the red stuff gives off a lot less dust to clean off the wheels...and I hate cleaning wheels!! 2019 5.0 SC SVA (Current)
