![]() | Home > Technical > Tyre Size |
Tiny Timmy Member Since: 20 May 2011 Location: Bucks Posts: 233 ![]() ![]() ![]() |
Oh I didn't realise that |
Slim444 Member Since: 09 Nov 2015 Location: Huntingdon Posts: 200 ![]() ![]() ![]() |
Spangler- if the speedo reads 8% less, then the odometer will too as they both run off the same sensor. All things being equal, can't be a bad thing, although maybe not so good for the next owner |
Spangler Member Since: 02 Mar 2019 Location: Kent Posts: 98 ![]() ![]() ![]() |
Had a gut feeling the odometer would be in sync - good news I guess |
Wow, 6% is quite a difference in the scheme of things!
Mixture of motorway and suburban driving i average around 24.5mpg - long distance motorway around 30mpg.
Sounds about right for a TDV8, but worth doing a proper measure if you haven't already- ie brim the tank, reset odometer etc etc... I have done this with mine and the computer lies by exactly 10%. My average over the last several thousand miles is 34.1mpg on the 'puter, which is 30.6 actual. That's a full 50/50 ish mix of urban and long distance. You can't see the eyes of the demon until him come callin' |
