![]() | Home > Technical > 2015 RRS found unlocked |
PIG88 Member Since: 23 May 2018 Location: North of Watford Posts: 194 ![]() ![]() |
I find that this happens from time to time on my 2016 RRS. For example, this evening the app says that the car is locked but not alarmed - but I have just checked and it has definitely been both locked and alarmed. Usually, when this happens, the ‘last contacted’ time is some hours ago - for example, this evening it says that the last contact was at 12.53 (see photo). I have come to the conclusion that it is a connectivity issue rather than any problem with the actual setting of the alarm.
The Kergan Member Since: 14 May 2011 Location: Wiltshire Posts: 294 ![]() ![]() ![]() |
The problem is my app is correct.
That is strange . . . .
Renaco Member Since: 28 Jul 2011 Location: Bavaria Posts: 324 ![]() ![]() |
That’s a real strange Situation. I had also only the wrong information on my app, but found the car always locked.
Yep always double lock it, I wonder if it’s possibe for someone to be using the same type of key with the same code and they open their car and mine at the same time 😳
Yep it’s still in warranty so will pop it in to them. 👌 2017 Range Rover Sport Autobiography |
