Home > Technical > Tyre Size |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
275/40/20 is the official standard size.
Thu Sep 05 2019 5:55pm |
Tiny Timmy Member Since: 20 May 2011 Location: Bucks Posts: 233 |
Ah ok thanks, They will be ok to get the same size then ? i dont want to mess up the suspension or anything!!!!???? |
Thu Sep 05 2019 6:09pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
I think 255/55/20 is either the Disco 4 size or someone has fitted RRS2 sized tyres to it by mistake (I think RRS2 uses 255/55/20). 2012 SDV6 - it's missing a couple of cylinders
Thu Sep 05 2019 6:10pm |
Maybe, i havent had it long so no way of knowing. The ride is nice, quite happy with it |
Thu Sep 05 2019 6:14pm |
Before you go for 275’s make sure the wheels are wide enough for them,yours might be complete wheels from a disco that someone has fitted & they aren’t as wide. Andy.
Thu Sep 05 2019 6:18pm |
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 200 |
Just fitted another set of 275/40/20 to my MY12, I looked at 45's when changing yet stayed with the stock profile. Had the geometry set again, wow what a difference! 2018 Telsa MS
Thu Sep 05 2019 6:21pm |
Im quite happy with my 255/55/20 to be honest, may just stick with them I think |
Thu Sep 05 2019 6:26pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4973 |
255/55 x 20 110Y is a Fullfat size tyre as well, fitted to a 8.5J rim.
Thu Sep 05 2019 11:15pm |
Cheers Col, weird why they have fitted them on mine They look good so I'll leave them on I think, as long as it's not doing any harm.. |
Fri Sep 06 2019 6:44am |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1167 |
255/55 was the standard size for ZA, not sure why.
Fri Sep 06 2019 7:14am |
Thanks Naks , its good to know. I didnt think it could get better |
Fri Sep 06 2019 8:16am |
Also a thing to remember is your speedo will not read accurate unless its been calibrated with new wheels.Put the sizes in here & it will give your the speeds ect.
Fri Sep 06 2019 10:36am |
Fri Sep 06 2019 11:01am |
Slim444 Member Since: 09 Nov 2015 Location: Huntingdon Posts: 200 |
255/55x20 is MASSIVE!!!!
Sat Sep 07 2019 2:35pm |
