![]() | Home > Technical > Tyre Size |
275/40/20 is the official standard size.
Tiny Timmy Member Since: 20 May 2011 Location: Bucks Posts: 233 ![]() ![]() ![]() |
Ah ok thanks, They will be ok to get the same size then ? i dont want to mess up the suspension or anything!!!!???? |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9029 ![]() ![]() ![]() |
I think 255/55/20 is either the Disco 4 size or someone has fitted RRS2 sized tyres to it by mistake (I think RRS2 uses 255/55/20). 2012 SDV6 - it's missing a couple of cylinders
Maybe, i havent had it long so no way of knowing. The ride is nice, quite happy with it |
Before you go for 275’s make sure the wheels are wide enough for them,yours might be complete wheels from a disco that someone has fitted & they aren’t as wide. Andy.
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 203 ![]() ![]() ![]() |
Just fitted another set of 275/40/20 to my MY12, I looked at 45's when changing yet stayed with the stock profile. Had the geometry set again, wow what a difference! 2018 Telsa MS
Im quite happy with my 255/55/20 to be honest, may just stick with them I think |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
255/55 x 20 110Y is a Fullfat size tyre as well, fitted to a 8.5J rim.
Cheers Col, weird why they have fitted them on mine |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1183 ![]() ![]() ![]() |
255/55 was the standard size for ZA, not sure why.
Thanks Naks , its good to know. I didnt think it could get better |
Also a thing to remember is your speedo will not read accurate unless its been calibrated with new wheels.Put the sizes in here & it will give your the speeds ect.
Slim444 Member Since: 09 Nov 2015 Location: Huntingdon Posts: 200 ![]() ![]() ![]() |
255/55x20 is MASSIVE!!!!
