![]() | Home > Maintenance & Modifications > Low speed vibration |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 872 ![]() ![]() |
Wheel balance is where I'd start. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
If you have just had a propshaft replaced personally that is where I would start, as something could be slightly out of balance or not aligned properly.
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 782 ![]() ![]() ![]() |
People have reported a vibration similar to going over rumble strips caused by a binding EPB. Something else worth checking. |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
Cheers. I just need it to stop raining... |
rover75 Member Since: 14 Mar 2019 Location: On my way Posts: 109 ![]() ![]() ![]() |
Not in a hurry then |
I spoke to our Indie friend who wasn't able to fit it in to have a look. He suggested that for the sake of a few quid, a good first stage would be to change the brake-light lamps. Extremely sceptical, this I did and this problem (and several others) has gone away completely. I took the car along the local dual-carriageway: problem evident. Came back home, changed the lamps and took another trip down the same dual-carriageway: problem fixed.
That is bloody strange! |
Weird, would never expect changing light bulbs would sort whole car shuddering problem - just odd |
On the D3, iffy brake lamps are known to cause suspension / HDC faults, but that's because the ECUs think the brakes aren't working. In one of the lamps the 5W filament looked iffy. I was starting to wonder whether I had inadvertently caused an earth loop when I wired-up the winch.
