![]() | Home > Technical > Revving on own? |
Try it in manual and do the same speed to see if it does the same fluctuations.
M9G UK Member Since: 02 Feb 2019 Location: Somerset Posts: 160 ![]() ![]() |
Oh yeah that's a good idea |
Ok so no it doesn't do it in manual, popped into my local garage as its already going in on Friday for a service, told the mechanic and hes going to plug diagnostics into it on Friday see if it comes up with anything. He did pull a face and say could be gearbox |
When was the last time the gearbox fluid was changed? Kev
Torque converter. A flush will likely cure it short term, but the underlying cause is a worn TC |
Beemer5 Member Since: 05 Sep 2018 Location: Penyffordd Posts: 33 ![]() ![]() ![]() |
Can the TC be changed without lifting thebody? ________________________________________
Yes, fairly straightforward job
aaronjb Member Since: 26 Jun 2019 Location: Northampton Posts: 447 ![]() ![]() |
Would that be a Haynes 1-spanner or 5-spanner job? |
I don't know, when I booked it in for a service I did say about the ATF and was quite shocked at the price so planned on doing that one next month Cheers 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys Xtrons Android head unit ![]() |
OK thanks ![]() Xtrons Android head unit ![]() |
I thought any gearbox work required body removal? 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys Xtrons Android head unit ![]() |
Really appreciate all you guys help and advice, it is a great community in here
No, not at all ![]() If there are no dramas, its a days work |
OK thankyou |
