![]() | Home > General (L494) > My16 DPF ssues ...41.5k miles on vlock |
I’ve had exactly same problem with my15 AB twice the orange exhaust filter came on so took it for a run kept in sport mode & 4th gear after 15-20 minutes light went off,the 2 weeks ago going to Tamworth for daughters wedding engine management light come on & went into limp mode,I got car to hotel where we were all meeting & within 10 minutes LR assist arrived plugged diagnostics in & same code P0234 came up turbo/supercharge overboost & it was my throttle body sticking that had caused it to go into limp mode so he took the front pipe off the throttle body freed it with some throttle body cleaner.The dpf on mine was showing 31% which LR only allow 30% now instead of the 60% they used to have before the light came on so the technician took it for a blast down the M42 to do a regen.
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
They do like to try and have you over don't they. Check out the Consumer Rights Act 2015, its the traders responsibility to fix it.If it costs more than £1,000 then they should stand the extra; a fault within 6 months is accepted to being present when you bought the car unless the trader can prove it wasn't. Did you use your credit card for even part of the purchase? If so you may be able to get them involved to help resolve this if the trader fobs you off.
Spleen Member Since: 04 Dec 2018 Location: Berkshire Posts: 175 ![]() ![]() |
Odd, my EML came on the other week so called LR assist. As you, error code showed overboost so they replaced the throttle body there and then. DPF check showed 39% but at no point has my DPF amber warning light come on so not sure about the 30% threshold. Ferrari F430 Spider F1 MY17 RRS AB V6 2CV6 Special |
Morning spleen,the technician told me they used to be set at 60% before light came on but they have now lowered it to 30%,I would have thought yours would be 30% seeing as it’s a my17.Mine was reading 31% when red exhaust filter light came on. Andy.
That's what I mean, mine is currently sitting at 39% but I've never had an amber (or red) DPF warning light. V strange. Ferrari F430 Spider F1
This is the report the technician game me.
Ash3 Member Since: 31 Aug 2019 Location: London Posts: 279 ![]() ![]() |
Unfortunately I paid by bank transfer ![]() When ai spoke to them the guy did not try and get out of it...he said get it checked out, see what it is and we will have discussion. Whatever that means. |
Thanks..that is useful to know... |
Thinking back When EML light came on with Amber DPF warning...I had the turbo fault code but no drop in power or throttle response. Car drove normally. Then yesterday when I took it for a blast on motorway the DPF light extinguished....but then 15 mins later came back as RED DPF warnning light with EML...but I was able to cruise at 50mph..some times it would go over 50. I did not try pushing it anymore. What speed does it limit car when in limp home mode and does it give any warning to say power restricted.? Thanks guys...this definitely the best forum for friendly, knowledgeable and helpful members. |
Struggling to read it to be honest, what's the word after 31? I had no need for a forced region at 39% especially as I was just about to go on a 3000 mile round trip to Europe. Tech talked about doing one but said DPF was fine after reading it. Ferrari F430 Spider F1 MY17 RRS AB V6 2CV6 Special |
The word after 31 is grams 31 grams of soot in the system.
Hmm, I wonder how much percent 31 grams represents? Ferrari F430 Spider F1
Here is a pic on what to remove,can you see the metal clip I’ve circled in green just above the white mark,lift that with a screw driver & then pull the pipe off revealing the flap in the throttle body,just push against it to make sure it moves if not that’s your problem,push it to fire it.
Thanks tyrefitter...will give it a try. ![]() |
