![]() | Home > Technical > Random beeping |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 ![]() ![]() ![]() |
Is it possible that it has a tracker? Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
Simonhunt72 Member Since: 13 Jan 2019 Location: Somerset Posts: 68 ![]() ![]() ![]() |
Hoppy, no I'm sure it doesn't?! Its really only been doing it last couple weeks constantly, was quite random before , and nothing when I bought it!!!!!!!! |
Tow bar fitted? 2019 5.0 SC SVA (Current)
Detachable yes , as in factory fitted brit |
I wondered if it may have been aftermarket with one of those black boxes but not if it’s factory.
It's pretty constant now as well , even get double beep on turning ignition!!! |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5042 ![]() ![]() ![]() |
What year is the vehicle? as the earlier cars had a speaker behind the n/s boot trim panel below the window for the parking sensors, not coming from that by any chance, could unplug it I suppose would at least eliminate it as a possibility.
It's a 2006 model Col , |
It's a 2006 model Col , and sensors are working ok ,at the moment!!if it makes sense it's a totally different noise to the rear sensor beep!! |
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 ![]() ![]() ![]() |
I'd go and listen to where the beeping is coming from then just remove the trim in that area, should be quite easy to find now its sounding that often. Then post a picture of the offending item. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
is it doing it when the car is still and or crawling along? |
Andy k slowly yes, not sure on stationary |
Is the noise coming from the dash?
No it seem to be from the rear! |
