Home > Technical > Random beeping |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 |
Is it possible that it has a tracker? Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
Fri Aug 23 2019 8:40pm |
Simonhunt72 Member Since: 13 Jan 2019 Location: Somerset Posts: 68 |
Hoppy, no I'm sure it doesn't?! Its really only been doing it last couple weeks constantly, was quite random before , and nothing when I bought it!!!!!!!! |
Sat Aug 24 2019 10:24am |
Tow bar fitted? 2019 5.0 SC SVA (Current)
Sat Aug 24 2019 1:46pm |
Detachable yes , as in factory fitted brit |
Sat Aug 24 2019 1:51pm |
I wondered if it may have been aftermarket with one of those black boxes but not if it’s factory.
Sat Aug 24 2019 5:18pm |
It's pretty constant now as well , even get double beep on turning ignition!!! |
Tue Aug 27 2019 10:19am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
What year is the vehicle? as the earlier cars had a speaker behind the n/s boot trim panel below the window for the parking sensors, not coming from that by any chance, could unplug it I suppose would at least eliminate it as a possibility.
Tue Aug 27 2019 10:38am |
It's a 2006 model Col , |
Tue Aug 27 2019 10:51am |
It's a 2006 model Col , and sensors are working ok ,at the moment!!if it makes sense it's a totally different noise to the rear sensor beep!! |
Tue Aug 27 2019 10:52am |
david007 Member Since: 20 Jun 2017 Location: Forfar Posts: 166 |
I'd go and listen to where the beeping is coming from then just remove the trim in that area, should be quite easy to find now its sounding that often. Then post a picture of the offending item. |
Tue Aug 27 2019 11:09am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
is it doing it when the car is still and or crawling along? |
Tue Aug 27 2019 5:03pm |
Andy k slowly yes, not sure on stationary |
Tue Aug 27 2019 6:59pm |
Is the noise coming from the dash?
Tue Aug 27 2019 8:16pm |
No it seem to be from the rear! |
Tue Aug 27 2019 9:36pm |
