Home > Faults & Fixes > Car won’t start, parking light on
hh
United Kingdom 2010 Range Rover Sport 3.0 TDV6 SE Java Black
Hi All rr sport 2010, turns off car was running fine. Now it doesn’t even turn over all ignition lights on when trying to start. The parking brake light stays on when brake is off. Have tried to start with a booster pack with the same results.
Getting codes B1087 & P0A1A in the engine management test
Any suggestions are welcome as I’m in the middle of nowhere.
Post #585749 Fri Aug 23 2019 5:00pm
Fictivision
Norway 2006 Range Rover Sport TDV6 HSE Java Black
Probably alternator or starter has failed.
Post #585758 Fri Aug 23 2019 7:16pm
Those codes are incomplete, there should be another couple of digits, but all point to similar thing.
Post #585766 Fri Aug 23 2019 10:46pm
