Home > Technical > Cornering light 2011 range rover sport
ryan_holton
Hi, I have a 2011 Range Rover Sport, 3.0L HSE. I've noticed that I appear to have a cornering light, I assume when the lights are on, and I turn the wheel, the cornering light comes on, however, this doesn't seem to be the case. Today, in the rain, and a slight overcast dim day, the green sidelight light on the dash was on, I have auto lights. I turned the sterring wheel full-lock to the right, got out and had a look, the LED sidelights, and Xenon low beams were on, but the cornering lamp, I assume because it's on the corner and there's a bulb in there, wasn't on? I turned it to the opposite lock, and the other side didn't light up either.
In both situations, the car is in Park, with the handbrake on, and the light switch set to low beam, I tried turning the main beam on, and still it doesn't work.
How do the cornering lights come on, do I need to be in a certain mode, e.g: sport? Or??
Post #585428 Fri Aug 16 2019 7:40pm
Oldandconfused
On my 2010, you have to put the indicator on in addition to having the lights on.
Post #585430 Fri Aug 16 2019 8:28pm
Stu
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
Does the vehicle not have to be between a certain speed range for this to work. Current: 2010 RRS 3.6 TDV8 HSE
Past: 2012 4.4 TDV8 Vogue
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
1988 3.5 V8 EFI Vogue
Others: 2007 VW Touareg 3.0 V6
1998 Jeep Grand Cherokee 4.0
1990 Mitsubishi Shogun 2.6
Post #585434 Fri Aug 16 2019 9:17pm
Anno43
I notice mine come on and off when cornering around my estate, turning into drive and sharp corners on country roads doing around 20 mph.
I’m sure they’ll be something in manual about the exact speeds it’s activated from and to.
Post #585435 Fri Aug 16 2019 9:25pm
They only work with dipped headlights, ignition on/engine running and car in Drive, will work with or without indicator going and deactivate above 25mph I think.
Post #585438 Fri Aug 16 2019 10:02pm
Brit Plumber
Mine are as Col said except mine work in reverse also (but work opposite, i.e. if I am in drive and turning right, the right lamp comes on, but if I leave the steering alone and put it in reverse, the left lamp comes on which makes sense) they also work at least 40mph as I have a fun corner near home that I like to throw it around at 2am. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #585442 Fri Aug 16 2019 10:55pm
Are we talking about the Cornering lights or AFS "bendy lights" as thought they deactivated at around 45mph, as for cornering lamps mine certainly only work in drive.
Post #585444 Fri Aug 16 2019 11:07pm
May need to be moving
Don’t worry.
Just test in a night time drive
Post #585470 Sat Aug 17 2019 12:58pm
Cornering lights will work with vehicle stationary provided transmission is in drive, or at least mine do.
Post #585472 Sat Aug 17 2019 1:14pm
Oliverx5
Spain 2010 Range Rover Sport Supercharged Arctic Frost
Hi, I have a LHD RR supercharged 2009 facelift model, I’ve just exported the car to Spain and subsequently changed he whole head lamp due to the fact the ones on he car were UK Spec. The lights I have purchased are Valeo, the reference is almost identical but note I have the AFS warning light and the cornering light doesn’t work, I was wondering if I dismantled the old lamps and switched over the ballasts and all electric components will this fix the issue??
Many thanks In advance
Post #587244 Fri Sep 20 2019 11:38am
david007
United Kingdom 2011 Range Rover Sport SDV6 SE Vesuvius Orange
I'm sure someone will be along that might be able to confirm this, but is there not a setting that you can change in one of the menus that allows you to set the headlamps for either driving on the left or right rather than having to change the whole headlamp, or is it more to do with them being UK spec.
Post #587246 Fri Sep 20 2019 12:34pm
Oliverx5
Thank you for the reply, Unfortunately not as the previous owner had changed the lights and put UK spec Valeo ones
Post #587250 Fri Sep 20 2019 1:26pm
drb1709
Mine come on with the indicators as long as the lights are on, but only up to a certain speed, and also when on the move dependiant on the position of the steering wheel.
I couldn't get them to come on at all whilst staionary.
Dave
Post #587255 Fri Sep 20 2019 2:17pm
ilard
I have the Osram LEDFOG101 fitted (replaces OEM fog lights with daytime running lights, fog lights, and cornering lights and I highly recommend). So I get cornering from the headlamp as well as the fog lamp. Suffice it to say, I can see where I am going even if I cannot answer some of the questions on this thread. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #587283 Fri Sep 20 2019 9:09pm
bradtarga34
It could simply be that the bulbs are blown, it happened on my MY10 and had the bulbs changed when in service and all working again tickety boo
Post #587350 Sun Sep 22 2019 8:15pm
