Home > In Car Electronics > Sat Nav, Radio, TV, Reverse Sounds, Bluetooth all gone down
Page 2 of 3 <123>
dataman999
So....... I switched out the old Module behind the dashboard as everything pointed to this after checking all the cables (& by-passing each one) and other units in the line, for a 'working used model' same specification exactly.
Same thing - no change - luckily the 'used' module only cost £175 compared to a new one for £1500!!
So where do I go from here??
Any ideas would be appreciated............
Post #585117 Fri Aug 09 2019 11:08am
Ljdiscovery
United States 2006 Range Rover Sport 4.4 V8 HSE Giverney Green
Looks like something has gone haywire on our 2010 Range Rover sport. Main nav screen turns on to Range Rover logo for a five seconds and then shuts off for 60 seconds and the logo lights up again for five seconds and then shuts down again. There is a clicking when it shuts down It looks like it might be the control module, also known as the audio control module. Does anyone have the remove and replace instructions. I can’t find anything the identifies where the module is located or instructions on replacement. Or is it the screen itself. I have no radio no nav no cameras no phone. Truck drives normally. No dash warning lights. I pulled three codes with my gap tool.
1. U0184-00(2f) lost communication with audio unit
2. B1a85-96(2e) ambient light sensor circuit -component failure-internal failure
3. U0010-09(2a) medium speed can communications bus.
Thanks. Phil
Post #585152 Sat Aug 10 2019 12:19pm
U0184-00
Lost communications
with radio - No sub
type information
Lost communication
with the integrated
audio module
NOTE: This DTC may be stored even though no fault condition is present and should be ignored unless the customer has
reported an information and entertainment system concern. Clear the DTC and retest. Verify the customer concern prior to
diagnosis
Using the manufacturer approved diagnostic system, complete a MOST network integrity test
Refer to the electrical circuit diagrams and check the power and ground connections to the integrated audio module
Refer to the electrical circuit diagrams and check the MOST circuit between the touch screen and the integrated audio
module.
Post #585154 Sat Aug 10 2019 12:46pm
Ljdiscovery
Is the integrated audio module the cd unit mounted below the nav screen to which the key antenna mounts to the bottom. Phil
Post #585155 Sat Aug 10 2019 12:54pm
Brit Plumber
Yes that’s it, I’ve put instructions on how to remove in a few posts.
The IAM is the SAT NAV, BT, CD, DVD etc. The FCDIM (the screen) is the controller for the MOST and gateway for the HS and MS can. If you have a code reader, can you call up the list of modules installed and see if it gives you details of the IAM and FCDIM (touch screen). 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #585162 Sat Aug 10 2019 2:16pm
dataman999
So - its not the big unit under the screen - garage says its the Amp (for which I have to pay full whack of £847 + VAT as each Amp (& screen I'm told) is specifically programmed to my vehicle.
Can this be true????
Post #585256 Mon Aug 12 2019 2:37pm
Brit Plumber
The AMP isn’t programmed or if it is, it has bothered my car! I’m running a 2016 Disco 4 AMP in mine with no issues. I’m also running a Dual View RRS screen from a 2013 car as mine was standard. The only thing I get is a code when I fit another IAM and that tells me it needs programming but it works fine. Get the eng number off you AMP and get one from eBay. 2019 5.0 SC SVA (Current)
Post #585281 Tue Aug 13 2019 7:31am
With the Audio Amp the workshop manual specifically says something about if a new unit is fitted it needs to be calibrated, not really sure exactly what that entails, or if needs doing if fitting a second hand one.
Post #585282 Tue Aug 13 2019 8:09am
dataman999
I am being told that the Amp has to be specifically coded to the VIN Number. (so does the display) and the only thing which doesn't is the (2nd hand unit which I've already purchased off Ebay) ?????
Post #585283 Tue Aug 13 2019 8:17am
No mention of having to code it to VIN No. unless that is what they mean by calibrate the component.
Post #585285 Tue Aug 13 2019 8:25am
dataman999
My service guy said he has to plug in the diagnostic kit (Autologic) to programme the Amp to the VIN - which is what Autologic and Land rover said to him too. ???
Dataman
Post #585286 Tue Aug 13 2019 8:48am
Brit Plumber
I will put my IID tool on my car and check but I’m pretty sure the AMP doesn’t register a VIN. Like I said above, I have a 2016 Disco 4 AMP fitted and a 2013 sport Dual View screen and no DTCs or Calibration warnings. I’ve also retro fitted a complete 2016 Disco 4 Meridian system into a 2013 Disco 4 XS with no DTCs. A new unit may need configuring as it’s probably blank and could be used in any vehicle but a used one with the same part number shouldn’t .
I’ll check my car this evening. 2019 5.0 SC SVA (Current)
Post #585289 Tue Aug 13 2019 10:41am
Brit Plumber
In regards to the screen, I think by coding they may mean editing the CCF to match the vehicle. The FCDIM has a abridged CCF in it so if you have say surround cameras and your doner car didn’t, that option needs to be activated on the doner FCDIM to match the CCF in the BCM. To code it, they probably use the VIN which will correlate to the As Built CCF but the unit doesn’t need it to function.
Using a VIN on my car would be hopeless as I’ve retro fitted lots of stuff (some options, some not) and would probably stop it all working until edited. 2019 5.0 SC SVA (Current)
Post #585291 Tue Aug 13 2019 10:48am
dataman999
OK thanks Very Happy
Post #585292 Tue Aug 13 2019 10:49am
Brit Plumber
Did a check of mine last night.
Post #585331 Wed Aug 14 2019 7:47am
Page 2 of 3 <123>
