Home > Technical > Changing battery |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
Just make sure the ignition is off and then disconnect the negative terminal. That'll be fine. Kev
Wed Jun 26 2019 4:07am |
N60613 Member Since: 24 Jun 2016 Location: capljina Posts: 32 |
turn ignition off, wait 10 min. then disconnect. RR 2012 4.4 TDV8 |
Wed Jun 26 2019 6:52am |
My car has a label next to the battery which I think shows IGN off, wait 2 minutes to power down, then remove neg battery clamp. Ignore my pointer, the photo was for another chap.
Wed Jun 26 2019 8:17am |
DEVON Member Since: 14 Apr 2016 Location: Bolton Posts: 264 |
Hi guys
Fri Aug 09 2019 8:23pm |
Ljdiscovery Member Since: 30 Apr 2016 Location: La Jolla, california Posts: 42 |
You only need to connect the vent tube if you have a vented battery. Some are sealed. Phil |
Sat Aug 10 2019 12:39am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
It’s more important when batteries are in the boot.
Sat Aug 10 2019 8:08am |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Remember to reset the BMS, plus the battery should be an AGM battery, loads of info on here and the Disco Forum...Fussy animals these cars In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Sat Aug 10 2019 8:13am |
Why AGM? My original LR battery wasn’t. 2019 5.0 SC SVA (Current)
Sat Aug 10 2019 8:32am |
Both my sports came with an AGM battery as standard In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Sat Aug 10 2019 8:35am |
We’re they L320s? 2019 5.0 SC SVA (Current)
Sat Aug 10 2019 8:46am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4973 |
My S/C certainly never came with a AGM as standard, although I have fitted one now.
Sat Aug 10 2019 8:48am |
LR AGM here from new, thought all Facelift had them fitted 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Sat Aug 10 2019 9:15am |
As normal L/R confuse things, RRS1 Petrol Variants only ever had wet cell batteries fitted, 3.0 and 3.6 up to VIN No. BA716316 had wet batteries, BA716317 on had AGM's fitted.
Sat Aug 10 2019 9:39am |
Thanks for all the replies guys
Sat Aug 10 2019 9:17pm |
