Home > Faults & Fixes > Upshifting Revs Drop?!
dxviiss
2011 Range Rover Sport 3.0 TDV6 Autobiography Fuji White
Hi All,
New to the forum - so hello to you all!
I purchased a ‘61 plate RRS (Stormer Edition) about a month ago. Absolutely love it, however I’ve noticed one issue that I’m not too comfortable with. It’s still got 2 months on Dealer all inclusive warranty to would like some advice to hopefully find a solution and get it sorted! It’s only got 55k miles and had both timing belts changed and service done before sale.
I’ve noticed that when shifting from 2nd to 3rd gear (in auto mode) the gearbox seems to try to change but then hang on to the gear slightly longer and then finally change. It doesn’t seem to happen in M/S mode.
I have tried the trick of ‘resetting’ the transmission memory by holding down accelerator etc (not sure if it works). But hasn’t seemed to do anything.
Anyone else familiar with the problem? I’m not mechanically minded at all, but would like to atleast have a place to start to look.
Any help is greatly appreciated! Very Happy
Post #585091 Thu Aug 08 2019 10:45am
knwatkins
It may be worth doing a fluid flush on the transmission. It isn't in the service schedule but recommended by the OEM. Kev
Post #585096 Thu Aug 08 2019 1:42pm
gogsy1956
I stand corrected if I'm wrong but not heard about this resetting the Gearbox by holding the accelerator down. I thought it had to be done using a suitable plug in device, normally done as part of the Gearbox flush. I had this done,, as have many others, and the Gearbox was reset so that it basically re- learns your driving style. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #585104 Thu Aug 08 2019 5:38pm
dxviiss
Thank you both for your input. Much appreciated!
I’m thinking of getting a flush and gearbox service done.
Not sure if it would be related but when cruising, if I lift off the accelerator the revs drop and then return to normal. I’ve heard it could need the throttle body cleaned.
Anyone else had this?
Post #585127 Fri Aug 09 2019 2:15pm
Stu
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
The gearbox reset is something which was mentioned on a number of occasions on the FFRR forum!
If I remember correctly, it’s pedal to floor with ignition off, ignition to position 2, hold pedal down for 60 secs, ignition off & release pedal.
Worth a go!.. Thumbs Up Current: 2010 RRS 3.6 TDV8 HSE
Past: 2012 4.4 TDV8 Vogue
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
1988 3.5 V8 EFI Vogue
Others: 2007 VW Touareg 3.0 V6
1998 Jeep Grand Cherokee 4.0
1990 Mitsubishi Shogun 2.6
Post #585153 Sat Aug 10 2019 12:23pm
