Home > Faults & Fixes > Upshifting Revs Drop?! |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
It may be worth doing a fluid flush on the transmission. It isn't in the service schedule but recommended by the OEM. Kev
Thu Aug 08 2019 1:42pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
I stand corrected if I'm wrong but not heard about this resetting the Gearbox by holding the accelerator down. I thought it had to be done using a suitable plug in device, normally done as part of the Gearbox flush. I had this done,, as have many others, and the Gearbox was reset so that it basically re- learns your driving style. 2010 RRS, TDV8
Thu Aug 08 2019 5:38pm |
dxviiss Member Since: 08 Aug 2019 Location: Cambridge, UK Posts: 2 |
Thank you both for your input. Much appreciated!
Fri Aug 09 2019 2:15pm |
Stu Member Since: 23 Jun 2019 Location: North Yorkshire Posts: 123 |
The gearbox reset is something which was mentioned on a number of occasions on the FFRR forum!
Sat Aug 10 2019 12:23pm |
