Home > Wheels & Tyres > Cracked alloy......Refurb??
djb222
A week ago last Friday I had a new set of Avon XZ7 tyres fitted, before a trip to Cornwall. Just before setting out I did all the usual checks and adjusted the tyre pressures....
While away I noticed the NSF tyre looked low, checked pressure and it read 12psi, so re inflated....next morning the same.
Anyway managed to get home and took it to the tyre fitters, they checked it and said they could not find a leak, so back home checked myself and found a leaky valve....they then refitted the tyre. Next morning flat again.
Back at the tyre fitters, refitted then re checked for leaks and found the inside rim has a crack.
SO I know that I can have it welded, however it doesn't sit right with me. Anyone had a cracked alloy welded? It's a LR wheel.
Post #560035 Wed Jun 27 2018 2:55pm
scousefly
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
Just DONT
do it Exclamation Exclamation Exclamation
What happens if you get it welded then your on another trip and have a blow out or worse because of a weld? By law they should ban this from happening especially when it involves a 2.5 tonne machine
Sorry possibly not what u want to hear but I feel that strongly about it
Post #560054 Wed Jun 27 2018 5:50pm
RAW
Better off posting what style and size wheel you need on here and see if anyone has one. MY18 RRS Autobiography Fuji White
MY15 D4 Commercial Indus Silver
Post #560057 Wed Jun 27 2018 6:14pm
Tyrefitter
Don’t have it welded,,they never last,I’ve seen plenty that have been welded & within a couple of weeks they crack at the side of the weld.
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #560058 Wed Jun 27 2018 6:15pm
djb222
Thanks Guys, that's exactly my feelings. It just didn't sit well with me when someone suggested that's what I should do....especially as my degree was in Metallurgy!!!!!!
I have posted a wanted add.
Post #560063 Wed Jun 27 2018 6:42pm
Baz0195
England 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Hi there, sorry I’m late to the chat. I had my 22” rear near side wheel welded due to a cracked inside rim over 12 months ago & it’s still going strong 🤞🏻 I suppose it depends who welded it, But just had a new tyre fitted to the front near side due to a puncture & after a week & a half it’s flat this morning 😤 took it to a tyre shop & the tyre was fine but it was leaking on the inside rim so had to have it bead sealed 🤷🏼‍♂️ They assured me it will be fine as that’s what it is designed for as I was a bit sceptical 🤨 any thoughts 🤔
Post #585077 Wed Aug 07 2019 7:27pm
Tyrefitter
Gaz,the fitter should have cleaned the rim on the inside before fitting tyres,I hope he didn’t use the black gluey stuff as that is no good on alloys,they do a cream paste like stuff for alloys when they leak on the rims. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #585078 Wed Aug 07 2019 7:34pm
aaronjb
I was in Brid last weekend .. I was half tempted to find out where you work (assuming you are still a Tyrefitter Wink) and bring the RRS up so a trustworthy tyre place could do the same for me - one tyre leaks like a sieve around the rim.. Whistle 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #585084 Thu Aug 08 2019 7:21am
RRS is a heavy vehicle, I wouldn't take the chance with a refurb.
I'm sure you can go to a scrapyard and buy the spare wheel from a wrecked one? --
Post #585085 Thu Aug 08 2019 8:29am
Tyrefitter
I don’t open on a weekends,which RRS yougot as I see loads on a weekends in town.My place is just behind Morrison’s supermarket Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #585100 Thu Aug 08 2019 4:38pm
aaronjb
A santorini black 2010 TDV8 - though you wouldn't have spotted that last weekend; I suffered a bout of CBA and didn't pump the tyres up, so came up in the 650i instead Wink Not sure which is worse on fuel, really.. Laughing Laughing
Drove in past Morrisons, though Thumbs Up I see they've finished digging everything up around Tesco since the last time I came up.. 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #585102 Thu Aug 08 2019 5:07pm
Puslinch
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
I had 22"s welded after crack and never lasted. Went back to 20"s and never looked back, better ride and no a issues. 2018 Telsa MS
2012 Range Rover Sport HSE+
1990 Porsche 944
1985 LR 90 Soft top V8
Post #585103 Thu Aug 08 2019 5:20pm
djb222
An update on my damaged alloy.
After much thought I decided on a visit to a highly recommended specialist local to me. Once there the tyre was removed and the crack was revealed on the inner part of the rim. It was probably an inch in length. After some discussion about the process and a look at some of his work I decided to give it a go, contrary to what I said earlier in the thread. If it had been a more extensive crack it would have been a no no..... It's been fine since.
I did have a problem with another tyre suddenly start to exhibit a slow leak..... I couldn't find the source so before taking it to be refitted I tried the over inflation trick, which appears to have worked.
Post #585116 Fri Aug 09 2019 9:17am
SRE
Spain
Best bet post in the for sale and wanted, get a new rim. You should get a full set of rims for a couple of hundred. Even I have 4 or 5 rims of a 2011 laying around as I fitted different rims to mine, trouble is they are in Spain. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #585118 Fri Aug 09 2019 12:19pm
Rennywuk
I’ve just been to get my 22 inch onyx alloys refurbed only to find every wheel has at least one crack (11 in total).
I’m rapidly falling out of love with with my sc 4.2.
I also only have 8 now 9 posts so can’t put a wanted ad up.
On my!
Post #586240 Mon Sep 02 2019 1:21pm
