Home > Maintenance & Modifications > Tow bar
HughN
Wales
Tow bar
A little bit of tow-bar porn for you...
Probably a very effective plough off-road, but at least it won't drop out or corrode to nothing. Rolling Eyes
Post #585034 Tue Aug 06 2019 5:33pm
rangemogger
Spain 2008 Range Rover Sport TDV8 SE Rimini Red
I like it!! I tried to bought several times without luck for the delivery policies Censored TdV8 mapped and egr deleted , 265/60 r18 on Compomotive rims , Navarricos underbody protection , custom rocksliders , Devon44 hidden winch 9500i , IIDTool
Post #585040 Tue Aug 06 2019 7:34pm
Pufftmw
I can confirm the split hook rubs going through BombHole on Strata Florida Very Happy
Though that was on standard off-road, not with extra Easylift. Not rubbed it any other time and it is higher than the OE LR 3 pt adjustable.
Post #585044 Tue Aug 06 2019 9:18pm
garrycol
Australia
My tow bar - a bit neater when the actual hitch is not installed
IMG_0327
IMG_0458
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #585047 Wed Aug 07 2019 1:19am
HughN
Wales
Very subtle, Garry. What's with the rectangular socket on the wiring - is that an Australian thing?
Post #585048 Wed Aug 07 2019 5:52am
HughN
Wales
I think you've just given me a reason to go and try that - just to make sure... Very Happy
Post #585049 Wed Aug 07 2019 5:54am
Brit Plumber
It allows you to fit a square peg in to a round hole!
 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #585052 Wed Aug 07 2019 7:03am
HughN
Wales
^^^ How very "diverse": it can mate with different things without changing gender.
Post #585053 Wed Aug 07 2019 7:12am
garrycol
Australia
As explained above. LR is too tight to sell their cars in Australia with our wiring system for trailers/caravans. Eg we only have one power line from the car for both trailer tail lamps where your system has individual power to each tail lamp. Unfortunately for us one of those power lines our system powers our trailer electric brakes - the result in an unmodified system is the trailer brakes come on when you turn on the headlights in the car - you come to a screeching halt. The modification is easy but as you are buying an expensive car one would think LR would rig it up to suit the markets they are selling in.
As far as the plugs go - the black and white plugs are of a style used maybe 30 years ago but these days the most common plug is the flat style on the end of the pic above - hence the what we call "donkey dick" converters that are available at our spare parts stores.
So my donkey dick plugs into the car and the trailer into the other end.
The other odd thing with the LR design is that it does not detect LEDs in the trailer lighting and most of our trailers are LED. As a consequence we all have a module that plugs in between the plugs - it provides a load that is detected by the car so turning on the towing functions in the car but still letting the lighting power through to the trailer lights.
I have converted my camper and trailer to old style incandescent lamps but have a home made module if I need to tow a trailer with LEDs. Not sure about the UK but we have had LEDs as a common fit in our trailers since before the RRS/D3 was designed yet there is an issue for the car if the trailer has LEDs - I believe the same issue continues on with the D4 and later RR/RRS.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #585059 Wed Aug 07 2019 7:58am
Had to buy one of those here cost me equivalent of £130.00. Not only that they have smaller balls here as well.
Post #585061 Wed Aug 07 2019 8:10am
Brit Plumber
Rolling with laughter
No comment. 2019 5.0 SC SVA (Current)
Post #585062 Wed Aug 07 2019 8:13am
garrycol
Australia
Yes - I always thought Kiwis had small balls Laughing
We have 50mm balls here. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #585065 Wed Aug 07 2019 12:18pm
rangemogger
IMG_0327
IMG_0458
Garry
It is higher but you losed you rear recovery point... Whistle TdV8 mapped and egr deleted , 265/60 r18 on Compomotive rims , Navarricos underbody protection , custom rocksliders , Devon44 hidden winch 9500i , IIDTool
Post #585066 Wed Aug 07 2019 12:40pm
garrycol
Australia
Well no
IMG_0089 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #585081 Thu Aug 08 2019 1:39am
aaronjb
So not only do you have big balls in Aus, you also have enormous shackles.. Laughing 2014 BMW 530d Touring, 2006 BMW 650i, 2018 Mini Cooper S
Post #585083 Thu Aug 08 2019 7:20am
