Home > Technical > Height calibration problem |
The new sensor will need calibrating. Does this garage know what they are doing? They don’t sound like they have much LR experience.
Wed Jul 31 2019 3:13pm |
Did they put it in right tolerance mode? 2019 5.0 SC SVA (Current)
Wed Jul 31 2019 3:14pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
It sounds like a strange thing to do putting into off road mode when doing the height calibration. There is no need to do this.
Wed Jul 31 2019 3:46pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
Sometimes driving it around 30mph is a way to get the suspension down (for future reference)
Wed Jul 31 2019 4:43pm |
is the red suspension light on?
Wed Jul 31 2019 4:44pm |
dazahunter Member Since: 31 Jul 2019 Location: england Posts: 6 |
the car is back now,,after the garage found a small chaffe in the wire and the osf height sensor was a bit stiff,, replaced wire section and new height sensor.This allowed them to "reset" the car,,but didn't do a full calibration?
Fri Aug 02 2019 11:19am |
UPDATE,,Plugged into diag and cleared every fault,turned off turned back on and it raised itself. car drives fine,albeit a bit bouncy,no warning lights,goes upto of road,,lowers to standard,but requires 3 presses and hold to lower into access mode.No errors shown on dash for new sensor
Wed Jan 29 2020 4:21pm |
What happens when the access mode button is pressed once? Does it try to lower and then go to extended mode? Or does it simply do nothing? Kev
Wed Jan 29 2020 4:26pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 |
Hi Dazza,
Thu Jan 30 2020 10:33pm |
