Home > General > 2008 TDV8 BOTH TURBOS GÒNE RUN WITH 60 LITRES PETROL ALLEGE |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
If it was a misfuelling incident, your injectors are likely also shagged and worth looking at. Kev
Tue Jul 30 2019 9:57pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4969 |
If you have compression blowing out through air filters and oil filler/crankcase compression I think you have more than a mis-fuelling issue more like piston/valve damage. Could start with a cylinder compression test and crankcase breather if there is one. Only a suggestion.
Tue Jul 30 2019 10:43pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4940 |
Body off for turbo change
Tue Jul 30 2019 11:37pm |
Davidno64 Member Since: 27 Jul 2019 Location: Berwick. Melbourne, Victoria Posts: 22 |
Disconnect Turbo's from engine. By removing inter-cooler pipes *2 that run into inlet manifold (Top hoses). Turbo will run but not boosting engine. This will the run as a normally aspirated motor but with poor performance (good for idle and testing). If the basic motor is healthy, motor should start at this point, not be noisy, no excessive smoke, etc. If you cannot start or have issues, Turbo are not the cause of your fault.
Wed Jul 31 2019 5:21am |
Tobias75 Member Since: 30 Jul 2019 Location: Maidstone Posts: 16 |
I've taken both inlet hoses off and it will not run only chugs badly.
Wed Jul 31 2019 6:42am |
Wed Jul 31 2019 6:43am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
Was it a recent purchase from Copart? |
Wed Jul 31 2019 6:45am |
You may have an Oil leak or not. Not all leaks are visible. You may be burning Oil? or just that the car was not filled correctly. Previous faults for instance. Oil may have siphoned through DIPSTICK dependent on faults. All about know History of Car. With an unknown history. Make no assumptions and go back to basics. This Diesel will run without Turbos. So disconnect and diagnose the motor. At the same time listen for odd noises from motor and Turbos. They will still be spinning. From disconnected Manifold to Intercooler hoses, see if there is pressure and Air Flow. While checking this determine it there is too much Oil Mist in the flow. These do have PCV, taken from the back of motor to the Right hand side of motor. Going into Pipe from Air Filter to a Turbo. A PCV fault (think these are a filter arrangement, not a valve?) can cause issues, Oil use, Leaks, Bad running, etc. You can disconnect this, see if plums of Oil vapor exit pipe. Stop it entering engine, etc. It may be blocked filter or pressurizing?? Have fun. |
Wed Jul 31 2019 8:53am |
I removed the intake pipes from the intercooler to the inlet manifold as they was both sucking in when cranking.
Wed Jul 31 2019 10:06pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
Wouldn't air blowing out of the air intake system suggest the valves are stuck open? Suggesting broken valves on one bank.
Wed Jul 31 2019 11:21pm |
If your having fueling issues or other, engine will struggle. Add to that other issues, Eg: leaking Turbo's? they would add oil to inlet. In effect enriching the Fuel ration. Starting or running issues would be exasperated. With my limited experience (untrained) and my Son-in law to be (trained Diesel Mechanic) and Race Driver. Biggest issue with Diesel's is Fueling issues. With that it could be mechanical or Electrical (usually mechanical). Eg: a Diesel needs Air & Fuel. Assumption Diesels will always get Air (unless under Water), so Fuel id the big issue (Atomized Fuel). So injectors need to be working well. They run at super high pressure say70,000 PSI to above 100000 PSI and very small orifices in Injectors. An unseen dust partial could cause a blockage. Carbon build up on the Tip causes issues. No Electrical signal will cause an injector not to fire. A blockage, Low fuel pressure will cause a n injector not to fire. A leaking injector will cause a drop in fuel pressure (in Rail), thus causing all injectors not to fire. If it runs, you obviously have some Fuel Pressure and Electrical activity. Then it's a matter of timing & pressure or leaks, blockages, etc. Best is to get a OBD2 diagnostic SCAN TOOL. Look for fault codes and look at flow rates (Air/Fuel). Your enemy for $$$ id 8 cylinder but that gives you a comparison up to 8 time. If all compression is high but 1 cylinder. There is your fault area. Like; your injectors in 7 read similar and the 8th one is out. Again there is your fault area. You have a lot of work ahead of you. Especially when you have to learn the systems. **** My own car. A 2008, TDV8. After a catastrophe, started by a coolant leak and fuel leak. I had to replace a single injector. Then another injector and 8 Fuel Lines. Then main ECU & re-program. High Pressure Fuel pump (misdiagnosed by land Rover dealer) - fault was a leaky Injector. Replaced 8 injectors (Reconditioned). still having running issues, Smoke Rough idle, low power and now down to the cause? I think related to a high Fuel Trim Balance offset on Injector #4. Cause not yet known but suspect an electrical issue. When ECU blew, I think other ECU's in car had gone faulty. Effecting the CAN Bus operation and hence Main ECU operation??? (but only a suspicion at this stage).**** |
Thu Aug 01 2019 2:50am |
How about something like turbo's blew, disintegrated and dumped bits into the intake system which in turn got sucked into the engine and
Thu Aug 01 2019 3:47am |
I was wondering if the engine had run on its own oil (hence empty and knackered) |
Thu Aug 01 2019 11:03am |
Also back to your fist post. Fuel Pressure at 300?, this should be in the region of 10000 Plus, dependent on engine speed. 300 sounds like a fueling problem (Among other issues). Sounds like a leaking Fuel Injector. Dropping Rail pressure, not allowing all injectors to operate correctly. |
Thu Aug 01 2019 11:19am |
