Home > Maintenance & Modifications > Brakes squeaking
russ1@me.com
Brakes squeaking
The rear bakes on my 2016 rrs squeak when I brake, not all the time but enough to pee me off. I replaced the worn pads with new land rover Bremo ones and the discs looked fine. Squeal this there. Any ideas?
Post #584696 Tue Jul 30 2019 8:57pm
knwatkins
Did you fit the anti-squeal shims when you fitted your new pads?
Brake squeal is most attributed to the pads moving (vibrating at a high frequency) in the caliper carriers. You can buy special brake grease to apply to the back of pads where they make contact with the pistons on the caliper. Sometimes, brake pads come with this grease. Alternatively, you could go the 'old school' way and apply a bit of copper slip grease instead.
The grease effectively increases tension between the back of the pad and the piston, damping out any oscillations of the pad in the caliper carrier, thereby preventing squeal. Kev
Post #584699 Tue Jul 30 2019 9:31pm
russ1@me.com
The pads didn’t come with any shims but I did use copper slip... rear side it worse than the off side.....cheers for the help.
Post #584700 Tue Jul 30 2019 9:39pm
knwatkins
Actually, looking back at the pictures when I did mine, I don't think the pads on these vehicles have anti-squeal shims which would explain why you didn't get any! Sorry for the mis-information Embarassed I must be getting confused with my wifes car that I replaced the pads on recently.
If I were you, I'd strip it back down, give everything a good clean, especially at the point where the pads move within the carrier, lube up and re-assemble. Kev
Post #584703 Tue Jul 30 2019 9:55pm
BKHK
Check with the dealer if there is a TSB. When I had the same problem on my SC, the dealer said there was a TSB. It’s one thing they actually fixed on the car. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #584709 Wed Jul 31 2019 12:51am
The only thing that shut mine up, albeit a RRS1 S/C was EBC Redstuff pads not cheap but worth it to shut it up.
Post #584710 Wed Jul 31 2019 1:38am
russ1@me.com
Sorry what is tsb?
Post #584722 Wed Jul 31 2019 7:26am
Wenier
New Zealand 2010 Range Rover Sport TDV8 HSE Santorini Black
TSB - Technical Service Bulletin.
When the manufacturer finds an issue they release that so the dealers have a fix for it. 2010 RRS TDV8 181000km
2005 D3 TDV6 307000km
Post #584739 Wed Jul 31 2019 2:06pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
My front brakes squeak like an old style london taxi. But they do some job stopping this fat b*stard of a car in a hurry when required...
Post #584780 Wed Jul 31 2019 11:01pm
https://www.rrsport.co.uk/forum/topic44976...+squealing
Eventually introduced a so called "Anti Squeal" brake pad. LR093886
Post #584781 Wed Jul 31 2019 11:02pm
