Home > Wheels & Tyres > Tyre recomendations both on & off road |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
Michelin Cross Climate SUV for road use - work well in the winter as well as summer, are quiet and fuel efficient.
Fri Jul 19 2019 2:23pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 |
Another vote for the AT3s. Should be good for well over 30k miles but great in the wet and snow. I've done a very muddy pay n play in them and they kept going without embarrassing me in front of the heavily modded stuff - mind you the car is very capable too.
Fri Jul 19 2019 9:06pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 |
Been running AT’s for 20k + miles now and need to change due to slightly uneaven wear on the the near side and side wall damage. They are still legal but have lost a lot of confidence in them now in the wet as the front seems to be sliding without much effort so no good on country roads.
Fri Jul 19 2019 9:17pm |
What AT have you been running? 2012 SDV6 - it's missing a couple of cylinders
Fri Jul 19 2019 11:41pm |
I have been running the AT3 on 275/45/20 at 37psi all round |
Sat Jul 20 2019 7:13am |
Might be something else and not the tyres? My AT3s are over 20k too and spend the majority of their time on country roads but no loss of front end grip. I do run 19s though, so perhaps the extra sidewall (55) helps. |
Sat Jul 20 2019 7:51am |
Has anyone ran 55 profile on a 20" rim? is it even possible with no mods or good for the susspension? |
Tue Jul 30 2019 11:42am |
Stu Member Since: 23 Jun 2019 Location: North Yorkshire Posts: 123 |
PC76 I had 255x55x20 A/T 3’s on my FFRR, they were fabulous. I’ve used grabbers for years all my Discos and FFRR’s have had them. Getting a set of 275x45x20’s fitted on the RRS on Friday.
Tue Jul 30 2019 7:44pm |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 |
Not sure what to stick on my supercharged sport as not sure it AT3 will cope with all the power I no it’s only as fast as I press the pedal 61 AB 5.0 supercharged rocket
Tue Jul 30 2019 8:15pm |
ShooterNeil, I had A/T 3’s on my last FFRR, It was the 4.4 TDV8 which was tuned to run 350bhp and 900nm. The tyres are speed rated to 150 mph also. I think they will cope with you hooning around in your SC..
Wed Jul 31 2019 5:11am |
Hi All,
Wed Jul 31 2019 9:52am |
The difference is in the construction, the Hbrated will have only one top layer maybe and the V will have 2. Also the V rated will have stiffer sidewalls for let’s call it spirited driving the H will have softer walls for more comfort, and so it goes on. No point in paying for something you don’t need! So unless you balls out everywhere and like a stiffer ride (no pun intended ) go for the H rated one.. Current: 2010 RRS 3.6 TDV8 HSE
Wed Jul 31 2019 12:04pm |
