![]() | Home > Faults & Fixes > Smokey the Bear, TDV8 |
Davidno64 Member Since: 27 Jul 2019 Location: Berwick. Melbourne, Victoria Posts: 22 ![]() ![]() ![]() |
Hi all,
Yes compression test done (of sort). Only had a tester for petrol motor (160 PSI, and leaky), So I used that. Tested all cylinders on bank 1. I suspected this too but from what I could tell, all good? Compression Meter read high, 150 to 160 PSI but in actual fact more. When cranking meter was blown out of my hand each time and felt similar pressure. So I guessing about 240 plus PSI??? (Bank 1 is the side I had injector failure, so I was suspect on this bank. Bank 2 untested for compression. But when tested, had a lot of fuel come out of cylinder #1, and slightly wet in cylinder #2 & #4. (Cylinder #1 relates the the failed injector). |
Today I had a moment for some testing. Ran and warmed, minimal smoke while stationary. OBD diagnostics shows MAF readings out; idle & revs) by a substantial amount (a difference of 10000 units). Had swapped position of MAF and same result (not MAF sensors. though there is some variance).
Wenier Member Since: 09 Apr 2019 Location: Christchurch Posts: 15 ![]() ![]() ![]() |
Yes, I am aware this may be Cylinder #4 or not. As this is correction after an event has taken place, effecting angular velocity (engine speed). I have also discovered normal expected rage for correction would be about 900, not the 600 I am receiving. This discrepancy, I am guessing is due to removal of EGR. As all 7 Injectors are in the Ballpark of 600, I would expect this is normal correction for removed EGR. But the 1400 reading for Cylinder #4 is not normal being the odd one out. I am experiencing different flow readings from one bank to another (was leaning toward Turbo, but I think not?). I think? the difference in Air Flow reading is due to the 1400 reading of injector trim?? But what is the cause?? I am leaning toward either an electrical fault, tricking the computer or God Forbid a mechanical problem in a Cylinder. (Compression not measured accurately, But the did seem High and consistent to the feel). Still looking for answers. |
I wouldn't be linking the EGR's to anything. They should be closed at idle and you did say they were blanked so should have no input whatsoever to what is going on. There is no extra butterfly to block normal intake on the TDV8 so with it blanked off only air from intake can be used.
New tool arrived a few days ago, Compression Gauge. But rain, rain and more rain, every time I open the bonnet |
Been a while but progress, between the Rain I cause every time I open the Bonnet |
What's in the fridge? Member Since: 14 Aug 2019 Location: Nearest hedge to London Posts: 112 ![]() ![]() ![]() |
Good luck |
Without checking, less than 180,000 Km |
OK, What a pain. Been working on this between the Weather. Spring is here and believe it or not. For the most part it has still been raining heavy. |
Life gets in the way, but now back to fixing the Range Rover. |
OK, here we go. Finally some days without rain and a new part arrived. Took a stab in the dark but with an educated guess, I replaced it. Buying new, a Transfer Control Module.
