Home > Faults & Fixes > Smokey the Bear, TDV8 |
Davidno64 Member Since: 27 Jul 2019 Location: Berwick. Melbourne, Victoria Posts: 22 |
Hi all,
Sat Jul 27 2019 8:42am |
Yes compression test done (of sort). Only had a tester for petrol motor (160 PSI, and leaky), So I used that. Tested all cylinders on bank 1. I suspected this too but from what I could tell, all good? Compression Meter read high, 150 to 160 PSI but in actual fact more. When cranking meter was blown out of my hand each time and felt similar pressure. So I guessing about 240 plus PSI??? (Bank 1 is the side I had injector failure, so I was suspect on this bank. Bank 2 untested for compression. But when tested, had a lot of fuel come out of cylinder #1, and slightly wet in cylinder #2 & #4. (Cylinder #1 relates the the failed injector). |
Sun Jul 28 2019 11:10am |
Today I had a moment for some testing. Ran and warmed, minimal smoke while stationary. OBD diagnostics shows MAF readings out; idle & revs) by a substantial amount (a difference of 10000 units). Had swapped position of MAF and same result (not MAF sensors. though there is some variance).
Sun Jul 28 2019 11:27am |
Wenier Member Since: 09 Apr 2019 Location: Christchurch Posts: 15 |
Mon Jul 29 2019 6:09am |
Yes, I am aware this may be Cylinder #4 or not. As this is correction after an event has taken place, effecting angular velocity (engine speed). I have also discovered normal expected rage for correction would be about 900, not the 600 I am receiving. This discrepancy, I am guessing is due to removal of EGR. As all 7 Injectors are in the Ballpark of 600, I would expect this is normal correction for removed EGR. But the 1400 reading for Cylinder #4 is not normal being the odd one out. I am experiencing different flow readings from one bank to another (was leaning toward Turbo, but I think not?). I think? the difference in Air Flow reading is due to the 1400 reading of injector trim?? But what is the cause?? I am leaning toward either an electrical fault, tricking the computer or God Forbid a mechanical problem in a Cylinder. (Compression not measured accurately, But the did seem High and consistent to the feel). Still looking for answers. |
Mon Jul 29 2019 10:10am |
I wouldn't be linking the EGR's to anything. They should be closed at idle and you did say they were blanked so should have no input whatsoever to what is going on. There is no extra butterfly to block normal intake on the TDV8 so with it blanked off only air from intake can be used.
Tue Jul 30 2019 6:14am |
New tool arrived a few days ago, Compression Gauge. But rain, rain and more rain, every time I open the bonnet Anyway, disassy top of motor removed Glow plugs and adapter for Gauge, don't fit. So I spun one up using a File and Drill, Then Tapped a new thread onto it (8MM). Compression test done, Cold readings are: #1-360psi, #2-360psi, #3-355psi, #4-360psi, #5-355psi, #6-360psi, #7-360psi, #8-365psi. Compression readings are higher than I expected but good and more-so pretty consistent. So it seems mechanically engine fairly healthy (although a hot Compression test would be nice, but for more involved). As I have already changed the injectors with Reco units and substituted cylinder 4 injector with another. Seems my remaining fault is still Electrical Now the fun starts |
Mon Aug 12 2019 6:17am |
Been a while but progress, between the Rain I cause every time I open the Bonnet . Compression test done with good results, so re-assy a bit at a time while there is a glimmer of Sun-Shine . (Damn brittle vacuum lines). Although I am aware of faulty ECU's relating to suspension causing intermittent CAN BUS errors. I noticed the main plugs to the Main ECU (or PCM), some pins had pushed though . Thanks Land Rover Service. Re-Plugging this in (although not fully rectified), now #4 injector is running more normal, running rough but no smoke and all Injector Trim values varying. Car is waiting on a MAF (arrived damaged/ Ebay order). Injector trim is fluctuating between 1400 & 600 (previously sitting at 1400 only). All Injector Trim's are varying/fluctuating closer to what is expected.
Fri Sep 06 2019 6:50am |
What's in the fridge? Member Since: 14 Aug 2019 Location: Nearest hedge to London Posts: 112 |
Good luck
Fri Sep 06 2019 8:29am |
Without checking, less than 180,000 Km |
Sat Sep 07 2019 10:59am |
OK, What a pain. Been working on this between the Weather. Spring is here and believe it or not. For the most part it has still been raining heavy.
Tue Sep 17 2019 3:19pm |
Life gets in the way, but now back to fixing the Range Rover.
Thu Oct 03 2019 1:48pm |
OK, here we go. Finally some days without rain and a new part arrived. Took a stab in the dark but with an educated guess, I replaced it. Buying new, a Transfer Control Module.
Tue Nov 12 2019 9:27am |
2008 TDV8 Buckingham Blue- SOLD |
Tue Nov 12 2019 9:41am |
