Home > General > Reversing beepers
1stRangie
Scotland 2010 Range Rover Sport 3.0 TDV6 SE Zambezi Silver
Reversing beepers
Help anybody tell me if the volume can be turned up on the reversing beeps on a 2010? SE . Radio volume control still doesn’t make it loud enough when air con fan on etc Many Thsnks
Post #583848 Fri Jul 12 2019 6:09am
Brit Plumber
So your saying it’s still quiet, even when you turn the volume to max? Mine is horrific at full volume and it can be heard easily outside the car. Are you adjusting the volume while the beeps are on? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #583858 Fri Jul 12 2019 8:48am
1stRangie
Yes just tried it again volume control not doing a thing when beeping 🤷‍♂️Just blasting radio Thanks
Post #583861 Fri Jul 12 2019 9:17am
Not sure what you have on a MY10 car, I think it may be quite different but this is on a MY12/13 car with the later updated interface view. Setup/System/Volume Presets from the home screen
Post #583862 Fri Jul 12 2019 9:24am
